Question about Vacuums
I have an electrolux precision model EL8805. The brush has quit spinning.. Any suggestions?
    Scholar:
  • 161 Answers
- dirt in the moving parts (clean the brushes and area )
- broken gear in the brush?
Posted on Oct 17, 2013
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: The brush on my Electrolux Versatility will not
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Posted on Jan 29, 2011
  • 260 Answers
SOURCE: Brush assembly will no longer spin on carpet however the suction from the system is still good. Unit is only 5 years old.
Open and check for belt damage. Also make sre there isn't debris causing this error.
Posted on Apr 16, 2009
tvservice306
  • 458 Answers
SOURCE: I have an Ambassador canister model Electrolux.
CHECK TUBE-SUMO ACTIVE ( PART NO: 1131402-02 ) CONNECTION AND NOZZLE-SUMO ACTIVE OR REPLACED (PART NO: 1131400-02)
Posted on Dec 07, 2009
Changing belt on electrolux precision vacuum el8805
Remove the cover plate over the brush. some simple pull or drop down. What ever. Once exposed, the brush (Roller) will need to be pulled away from the frame sides. The brush ends are generally inserted in to plastic or rubber end plugs and must be pulled away from the case. Once away, the belt; is in one piece needs to be removed. One end is still around the vacuum motor shaft. Lit that off and discard it. Place a new drive belt at one end around the motor. Pull it down and attach the other potion to the brush roller and press the roller back in place. There is little movement of the Belt, and it must be tight, thus you may need to use e screwdriver to lift the roller in place.
Feb 09, 2018 | Electrolux Vacuums
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
My brush piece is corroded
El8807 - call customer service at 800-896-9756 push 1 or 2, then push 3. They sent me a new replacement, no cost. Need your Serial Number so they know date of purchase. 5 year warranty. Best vacuum ever, better than dyson and cheaper by 100%, but the brush stopped working after getting tangled. Called support and they replaced. Great. Cheers!!!
Apr 21, 2014 | Electrolux EL8807A Precision BrushRoll...
I have an issue with an Electrolux Precision EL8802 - I can't figure out how to access the belt. I have removed the bottom dust cover and roller, but the belt isn't visible and it's not apparent how you...
There is no belt. The brush is direct drive by a seperate motor. There is a motor reset switch that you use if the brush is not turning. If that does not fix the problem, you have to take the unit in for service http://manuals.electroluxusa.com/prodinfo_pdf/Edison/86668R4en.pdf
Feb 02, 2014 | Electrolux EL8807A Precision BrushRoll...
Burning smell
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
Jan 02, 2014 | Electrolux Central Vacuum
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
Vacuums Logo
546 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
