Question about Toshiba 42HPX95 42 in. Plasma Television
Fuse main board - Toshiba 42HPX95 42 in. Plasma Television
    Top Expert:
  • Toshiba Master
  • 75,311 Answers
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 17, 2013
Main power fuse location
The main power supply board houses the main fuse. Beware, some sets have multiple fuses on the main board. Besides a fuse, some sets have input filters for incoming power. These filters are before the main fuses, so if you have one, verify that you are getting power out of the filter
May 08, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
Orange light on vizio no bad caps
You may be buying a main board, only a few guys in the industry even bother servicing main boards. Outside of a bad cap, fuse, or regulator its time to replace the board. If you have standby power, and you're not getting the "PS ON" signal from the main board, your main board is bad!
Feb 08, 2013 | Vizio SV471XVT 47 in. LCD TV
Where are the fuses in my vizio vf550xvt
the main power supply fuse will be located on the power board. Just follow the power cord to the power board, the fuse will be close to the power connector. FYI, there are also fuses located on the main board, t-con, and inverter boards.
Dec 09, 2012 | Vizio Televison & Video
Where can i buy a circuit board for my lg refrigerator model lfc23760st
No need to buy a new main control board !
The problem is mainly from the fuse that soldered in the main control board, go to buy a "125V 15A or 250V 15A" fuse ($5.00 a pack of 5 pcs), cut the burnt fuse from the board, re-soldered the new fuse into the board, the refrigerator work again. you save $80 for the labour cost of the technician and $180 for the cost of a new main board.
Jul 18, 2012 | LG LFC23760ST Side by Side Bottom Freezer...
The mains input fuse (4amp) and a (1amp) fuse on the main power out board were blown. Replaced fuses and switched on, blown again, disconnected output from transformer to main board (4amp) fuse did not...
The cheapest option is to replace the transistors (a quick check on google will tell you how much they are). If they are common transistors you will be able to find them and get them quicker then searching for a board that could be no longer being made.
Sep 02, 2010 | Mackie SWA1501 Subwoofer
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
I have an LG WM2277HW washing machine. My wife went in this morning to do some laundry and the thing is completely dead. No lights or signs of life. I checked the house circuit and the power to the...
Make sure the noise filter connectors are clean and connected properly. Get yourself a multimeter and check the voltage both on the load side and line side of the noise filter. It should read the same at 120VAC. The noise filter is the board before the main board. Replace it if the voltages on its load and line side are not the same.
The main board is not serviceable and must be replaced if faulty. It has a fuse and if it is blown, the main board is probably faulty. Look at the two brown capacitors on the top left of the main board. Next to it is a heat sink and to its right is a white "fuse-like" component with silver ends. That is the main board fuse. If it is blown, disconnect all the connectors from the main board except the one connecting it to the noise filter. Jump a single thin strand of wire in place of the fuse and apply power to the machine. Check if the power LED indicator on the main board lights up. If it does not, the main board is dead, replace it.
Please do not hesitate to update me about your findings above for further guidance if necessary.
Jan 12, 2010 | LG WM-2277HW Front Load Washer
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Toshiba 42HPX95 42 in. Plasma Television Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
