Question about Hotpoint Refrigerators
Hotpoint HSS25GFTC BB The water dispenser is not
Hotpoint HSS25GFTC BB The water dispenser is not working nor is it making ice...please note before you post comments about frozen dispensers....BOTH not working. What ice that is there will dispense. When the water button is activated you can here the solenoid engage in the back I see no "tank" or coolant lines accessible from the crisper area, is it there and I need to rip things apart? There is water pressure at the filter and if you empty it...it will fill up. The door switch was tested and operating properly. Now what to test?
  • Shawn Feller Oct 17, 2013
    I should add that the valves in the back are showing about 0.300 K and 0.180 K ohms and engaging...atleast the water side. I also have water pressure all the way to the door at the bottom...I can shoot ig across the floor. I've already defrosted the unit and still no pressure. Plus the fact that it will not make ice and failed at the same time has me concerned for the logic board. One can hear the water dispense switch at the door engage and can be tested with the light/door open switch...plus one can hear a solinoid in the back engage, separate from the valves. We have electric working everywhere!
Rotu
  • 175 Answers
SOURCE: No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Posted on Dec 17, 2006
SOURCE: RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Posted on Oct 26, 2007
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
SOURCE: Kenmore water dispenser not working, side by side frig
no water come out of dispenser to glass
Posted on Aug 06, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Water dispenser not working
There are two electric valves for your ice maker One for water to make ice and the other is for your water dispenser. They can get clugged and will not dispense water. The two valves are sold together for $50 and they are right in the back of your Refrigertor where the water pipe ends. Hard water can clugg those tiny valves
good luck
Jul 31, 2009 | Refrigerators
I bought a Hotpoint refrigerator in early 2004 but did not have it delivered until late 2005. After about a year the water dispenser quit working. Ice dispenser would just drag at times. Then the water...
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 09, 2008 | Hotpoint HSS25GFP Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
Refrigerators Logo
81 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
