Question about Mitsubishi WD Televison & Video
Delayed start After replacing the lamp, the tv always delays the start as though it had been unplugged from power. Why?
  • 101 Answers
The new lamp just has a longer strike time than your old one. Every bulb is a little different and the strike time can be longer or shorter. If it is enough of annoyance, a new bulb would likely correct the problem.
Posted on Oct 17, 2013
5 Suggested Answers
  • 579 Answers
SOURCE: TV Powers off
I think the lamp cover switch is acting backwards. Should quit when the door is off, and only work when the door is on. Look closely at the cover switch and see if it is messed up somehow.
Posted on Jan 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: No Picture, already replace lamp. model RCA HD50L PW62AYX6
What model set do you have. I also work as a tech at another place that probaly has your troubleshooting guide for your light engine
Posted on Jan 17, 2008
  • 3 Answers
SOURCE: power button
that's normal. just a cool down period.
Posted on Aug 28, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: delayed video, audio comes first
It's normal for Sony TVs to have a delay in the video. The screen stays blanked until the circuitry in the set has decided that the picture tube is operating correctly. The screen can remain blanked due to a number of causes. Bad solder connections or components in the vertical output stage are common. Also, Sony sets automatically adjust some tube voltages. If the tube has aged enough or component values in the set have changed and the adjustments don't keep the values in the correct range, the screen will blank out. Intermittent components or connections in the set's video stages or source switching can cause screen blanking. Unfortunately, this is one of the tougher Sony problems to troubleshoot. It usually requires the schematic and an oscilloscope to track down.
Posted on May 03, 2009
Standby light flashes and TV won't turn on. Have to unplug it and wait for a bit then plug it back in and TV turns on. Quite a delay though. Then after TV is turned off, standby light starts...
seems like a power supply problem inside the tv and when the transformer gets warm it is giving you problems you might have to get a tech seviceman to come out and have a look at it as it is not a job you should do yourself when it comes to replacing the power supply hope all goes well
Jul 06, 2011 | Samsung LN52B530 LCD TV
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Tv has a delay when turning on
U know basic electronic's and soldering take the tv aparts,where the power a/c cord plug into it,that the power supply board.Searches these parts call capacitors,they alway bulges up on it tops or puff up on it tops.Replaced these dying leakages gases capacitors.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.These steps will stop the clicking noises and power up the tv quickly.
Jul 10, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Breadmaker Won't Start
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
Feb 09, 2008 | Black & Decker B2000 Bread Maker
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
