I need to wire up front panel block and speaker connector on a 138644-001 Motherboard
  • 61 Answers
Manufacturer will have connector pin map online in their docs for that board
Posted on Oct 18, 2013
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
I need a wiring manual for a g31t-lm2 motherboard...
Hello here is the drivers site:
http://support.lenovo.com/en_US/downloads/default.page?
Here is the user guide:
http://support.lenovo.com/en_US/guides-and-manuals/default.page?selector=expand
The front panel connector ( F panel) looks like this:
This is located in the down right corner.
The usb connectors look like this:
In your another case, there should be connectors for front usb and audio, what it goes for should be printed in on the connector.
Basicly this can not be connected wrong.
Good luck
Jan 26, 2013 | Lenovo g31t-lm2 - System Board
Need diagram for connection on motherboard 4006272r
Gateway 4006272R motherboard;
Foxconn (Bengal) RS780 motherboard.
[ In otherwords the motherboard chipset is an AMD RS780 series,
http://en.wikipedia.org/wiki/AMD_700_chipset_series#780G.2F780V
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Radeon_R600_series
Scroll down to the bold black subheading - IGP (HD 3xxx, HD 4xxx ]
This motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the list click on -> Product Views
Now click on -> S - Front Panel Connector
Motherboard installed in the computer case, the Front panel header is at the Bottom/Right corner.
It has -> F_PANEL <- silkscreened in white underneath it.
Two rows of pins.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side, coming across to the Right;
Top row;
Pins 2, 4, 6, 8, No pin, 12, and 14.
Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
Pins 11, 12, 13, and 14 are NOT USED.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
These pins are in the Orange blocks.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
These pins are in the Blue blocks.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
Black block.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
These pins are in the Green block.
E) Pins 6 and 8 are for the Power On switch.
These pins are in the Red block.
F) There is NO Pin 10.
Black block.
Again, Pins 11, 12, 13, and 14 are Not Used.
B- CPU Power Connector is at the upper left corner of the motherboard. This power cable is power for the Processor.
MUST be plugged in.
A general example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Note the Lock on the side of the power cable's connector, and matching Lock Tab on the motherboard connector.
F- Main Power Connector also has a Lock, and Lock Tab.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
D - CPU Fan Connector is above the processor socket, and near the top outside edge of the motherboard. ONLY plugs in one way.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 10, 2012 | Gateway Computers & Internet
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
My power led connector (green,white) power sw connector (black,white) got out of place and i dont where they go
The eMachines T3302 desktop computer, uses an FIC K8M-800M motherboard.
(First international Computer, Inc.)
Where those wires go on the motherboard, is termed a Front panel header.
The Front Panel is the plastic front bezel of your computer.
(Where the Power On button is, Power On LED light, and so on)
Looking at the motherboard with the Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the bottom right corner, and over to the left.
Look at the jumper block in the bottom right corner. Right in the corner.
This is the LED type selector, jumper block.
Has 6 pins.
3 across the Top, 3 across the Bottom.
(This jumper block is to set whether you are using a Power On LED light, that has Dual Colors, or a Single color.
The default setting of the jumper on the block, is set to use a Dual Color LED light, for the Power On LED)
Move to the left of this jumper block. The Front Panel header is to the left of this jumper block.
(FIC terms it a Front Panel Block Connector)
It should be White in color.
Is right against the bottom edge of the motherboard. (Parallel to the outside edge of the motherboard)
Has two rows of pins sticking up.
5 across the Top.
4 across the Bottom.
The pins are numbered from the Right, going towards the Left.
(From the Power On LED jumper block, towards the Front Panel header)
On the Top row going from Right, towards the Left,
Pins 1 ,3, 5, 7, and 9.
On the Bottom row going from the Right, towards the Left,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the Power On LED light.
(Green)
B) Pins 5 and 7 are for the Power On switch.
Pin 5 is for the Positive ( + ) wire.
(Black)
[Although it really doesn't matter which way the wires go. It's a SWITCH]
C) Pins 2 and 4 are for the HarDDrive activity LED.
Pin 2 is for the Positive wire ( + )
D) Pins 6 and 8 are for the Reset switch.
(IF used)
If any of your LED lights are dim, after attaching the Positive wire for each LED, it's because the Positive wire is on the wrong pin.
Switch the wires around
Aug 23, 2010 | E-Machines T3302 PC Desktop
I NEED DRAWING FOR THE FRONT PANEL CONNECTION
Download the manual for you're MSI PM8M-V motherboard from MSI; http://www.msi.com/index.php?func=searchresult&keywords=PM8M-V&table=download
You will need to download and install Adobe reader to view the manual. Download Adobe; http://www.adobe.com/products/reader/
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Cheers'
Mike
Apr 22, 2010 | MSI PM8M-V Motherboard
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
