thank you works like a champthank you works like a champ
AnonymousNov 21, 2007
i don't know where is the place to insert the sim card in the iphone can u help me please ?i don't know where is the place to insert the sim card in the iphone can u help me please ?
i have inserted my sim card and the phone says it is not recognizing my sim cardi have inserted my sim card and the phone says it is not recognizing my sim card
i put more pressure in pressing the small hole, and yet nothing happened. what will i do?thanks i put more pressure in pressing the small hole, and yet nothing happened. what will i do?thanks
AnonymousMay 15, 2008
i cannot get sim tray openi cannot get sim tray open
I have just purchased a p168. I have inserted my sim card into the slot and choosen for my sim 2 only to be opened and the phone keep saying to insert sim. I thought maybe the sim could not be used for this phone so i called my phone carrier and they told me that it could. Can somone please help me?I have just purchased a p168. I have inserted my sim card into the slot and choosen for my sim 2 only to be opened and the phone keep saying to insert sim. I thought maybe the sim could not be used for this phone so i called my phone carrier and they told me that it could. Can somone please help me?
AnonymousJul 06, 2008
how to insert sim in iphonehow to insert sim in iphone
Its in the side of iphone it has a little raised line with a hole the size of a pin use a pin and push it into that little hole and it will open.Its in the side of iphone it has a little raised line with a hole the size of a pin use a pin and push it into that little hole and it will open.
You can't post conmments that contain an email address.
On the top of your iphone next to the power button with a slot with a very small hole, there are two holes, one is the bigger one and the small one.
Use a paper pin and push the small hole, some might need to use more pressure than the other, that should pop out the existing sim and u can put urs in.
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted. 2. Turn off mobile phone 3. Remove battery 4. Remove memory card 5. Remove sim card 6. Check the copper pins of the sim if there are dirts stucked on it 7. Ure clean cloth to wipe sim gently 8. Wait for at least two minutes 9. Gently and properly insert the memory and sim card 10. Insert the battery 11. Turn on mobile phone 13. Check if you will still recieve insert sim error 14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
This is called Dual sim phone. Go to settings and make sure that the Dual Sim is enable. Whe a phone state "Insert Sim" after inserting the sim card, it is most probably that you had inserted the sim the wrong way, so that the gold connectors is not connecting with the phone. Invert the sim card and try. If the problem persist, try the other sim slot.
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
No SIM card inserted or inserted SIM card is damaged
Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
Likely Causes:
how do i insert my sim in my iphone?
how do I insert sim card in my new iphone
Where do u insert the sim card?
where and how to insert my simcard
how do i insert sim card in iphone
don't know where to insert sim card
i dont know how to get the sim card in
how to insert sim card in apple i phone
iphone
how do i inseret mysim card?
How do I insert the simcard into my new iPhone?
demo
sim card
demo
apple iphone
how do i open my iphone to insert my sim
