Question about Yard Machines Garden
Yard machine 158 front tine tiller does not start started once
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Posted on May 26, 2009
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
Belt broke on my 12 inch mtd yard machine front tine tiller model 21a-250m000 how do i replace it. thank you for your help!
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Feb 27, 2011 | Mtd Products Yard Machines 158CC Tiller
Ifound a Tecumseh Yard Machine Front Tine Tiller. It has a 5.50 HP. The tiller seems to choke out every time i crank it up. Can Someone tell mewhere the fuel filter is located???? i have replaced the air...
It sounds as if you still have Carburetor problems.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 05, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Yard Machines rototiller front tine- having problems starting
Sounds like you are either losing your "prime" or your carb needs either, cleaning, rebuilding with a kit. Probably a cleaning will do it. Watch U Tube there are wonderful people who film the whole process from tear down, to replacement. Com'on! Get into it its easy and it don't take long. Then you'll always know how to do it!
May 04, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Engine will not run/tecumseh enginelstall once it starts/hsk model
I assume this is on a snowblower?
Be sure you have fresh fuel.
You can also remove the bowl on the carb and spray carb cleaner in any orfice you see.
Always store a snowblower with fuel stabilizer in it. Otherwise it the fuel can "varnish" the inside of the carb and cause problem.
If it still doesn't start check compression.
Jan 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Tiller wont get fuel to start
Try disconnecting the line at the carb. Then carefully blow back to the tank. It may have something blocking the outet from the tank. If that doesn't do the trick, the float may be stuck and not allowing the needle to open for fuel to enter the carb bowl. Good luck...Lee
Aug 05, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Garden Logo
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
