Question about Ricoh Aficio Office Equipment & Supplies
WHAT IS ERROR CODE SC670 ON A RICOH AFICIO SP C240DN?
    Problem Solver:
  • 18 Answers
Engine start-up error.
I suggest that if switch the copier off/on doesnt resolve you call out an engineer - could be a main board fault or firmware.
Posted on Oct 21, 2013
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
Aficio sp c430dn error sc670. In service manual prepose to replace engine board. But i can find it. Is in SM engine board called Controller board? Also am trying to upgrade firmware. When I put in the
You cannot update firmware when there is an error condition. Reseat all the connections on the controller board. If it still fails then replace part number D0655715.
Nov 28, 2014 | Ricoh Aficio SP C430dn Laser Printer
Ricoh Aficio SP C420dn showing error code sc670. What does this mean?
The code is engine start up error "replace engine board, sorry...
Feb 06, 2014 | Ricoh Aficio Office Equipment & Supplies
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh mp6500 sc670 error code
sc670 is an engine startup error. A lot of times if you reset the copier (turn it off with the orange switch on the left side of the front cover, then turn it back on) the error will go away. If it doesn't the BCU board may need to be replaced.
Mar 16, 2011 | Ricoh Aficio AP3800C Laser Printer
I turn on my ricoh aficio 2027 this code SC670 APPEAR
670 D Engine response error After powering on the machine, a response is not received from the engine within 30 seconds. • SBCU installed incorrectly • SBCU defective • Controller board defective
You can try to reseat the connectors on those 2 boards, if that doesnt work you may need to replace those boards.
Mar 15, 2010 | Ricoh Aficio 1035 Copier
Error Code
HAD SAME PROB I WORK FOR RICOH DIRECT SERVICE 670 IS ENGINE CONTROL BOARD OK....
Feb 16, 2007 | Ricoh Aficio CL2000N Laser Printer
413 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
