Question about Lands Phones
TELEFONO INALAMBRICO ADP 5000
SOLO APARECE EN PANTALLA 00 3A TECLADO INHIBIDO
bhur
  • 85 Answers
SOURCE: telefono inalambrico kx-tg3031s
you may coldsolder the flash ic and cpu
Posted on May 29, 2008
nonontech
  • 4737 Answers
SOURCE: Necesito El manual en español
If I guess right, you are looking for a user manual for your VTech CS5121-3....... Cordless phone in Spanish. But unfortunately, this manual is available only in English, no other language. Even on the Vtechphones.com, it's not available.
If you need the English Version, you can download it from here (click here).
You'll need a pdf reader like adobe reader to open and read the file on your computer. Click here to download Adobe Reader.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 02, 2010
bbl242003
  • 1637 Answers
SOURCE: HOLA, NECESITO VER SI ME
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 19, 2011
  • 76 Answers
SOURCE: TENGO UN TELEFONO INALAMBRICO GENERAL
what are sida for any qustion for my face book problemme for any thing as
Posted on Jun 23, 2011
SOURCE: necesito el manual del telefono
necesito el istructivo del telefono inalambrico del modelo vetch 5.8 GHzme lo podian publicar porfavor
Posted on Jul 17, 2011
Como desbloquear regiones al blu ray
Hola soy de M?xico y tambi?n tuve el mismo problema mucho tiempo hasta que encontr? la soluci?n y aqu? te dejo paso a paso como hacerlo ;)
PASO A PASO: 1. Asegurate de que no hay ning?n disco en la bandeja.
2. Apaga el reproductor y vuelve a encenderlo (Esto es necesario para limpiar-arrancar el firmware)
3. Espera hasta que la p?gina del men? principal aparece y el reproductor ya no haga nada.
4. Pulsa el bot?n de expulsi?n para abrir la bandeja.
5. Pulsa el bot?n de expulsi?n para cerrar la bandeja.
6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado num?rico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA)
7. El c?digo de regi?n "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la regi?n free.
8. Apaga y enciende de nuevo el reproductor.
9. Disfruta de tus pel?culas :D :D :D
NOTA: MI REPRODUCTOR CUANDO LO HICE REGION FREE DEJO DE LEER LOS BLU RAY REGION 'A', POR LO QUE PARA QUE LOS LEA LO QUE HAGO ES VOLVER EL REPRODUCTOR A REGION 4 SIGUIENDO LOS MISMOS PASOS SOLO QUE CUANDO EL APARECE EL NUMERO (AHORA 9) EN LA ESQUINA PRESIONO 4 Y LISTO, AS? QUE SOLO LO PONGO FREE (9) CUANDO VOY A VER LOS DVD'S QUE SON DE OTRA REGION. SUERTE.
Apr 23, 2013 | Samsung BD-E5900 Smart-3D Blu-ray Player
Region code
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucion y aqui te dejo paso a paso como hacerlo ;)
PASO A PASO: 1. Asegurate de que no hay ningun disco en la bandeja.
3. Espera hasta que la pagina del menu principal aparece y el reproductor ya no haga nada.
4. Pulsa el boton de expulsion para abrir la bandeja.
5. Pulsa el boton de expulsion para cerrar la bandeja.
6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado numerico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA)
7. El codigo de region "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la region free.
9. Disfruta de tus peliculas :D :D :D
Mar 20, 2013 | Samsung BD-E5900 Smart-3D Blu-ray Player
Hello, recently purchased a Samsung BD-E5900, would it be possible to make it a region free player?
Sep 26, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
How to unlock Samsung BD-E5900
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucien y aqui te dejo paso a paso como hacerlo ;)
Jun 04, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
I have a samsung bde 5900 bluray player. Can someone help me unlock the region code?
NOTA: MI REPRODUCTOR CUANDO LO HICE REGION FREE DEJO DE LEER LOS BLU RAY REGION 'A', POR LO QUE PARA QUE LOS LEA LO QUE HAGO ES VOLVER EL REPRODUCTOR A REGION 4 SIGUIENDO LOS MISMOS PASOS SOLO QUE CUANDO EL APARECE EL NUMERO (AHORA 9) EN LA ESQUINA PRESIONO 4 Y LISTO, AS? QUE SOLO LO PONGO FREE (9) CUANDO VOY A VER LOS DVD'S QUE SON DE OTRA REGION. SUERTE..
May 28, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
PERDI MI MANUAL DEL TELEFONO INALAMBRICO BEETEL 2.4 GHZ DIGITAL, NECESITO REGISTRAR EL AURICULAR EN LA UNIDAD BASE.
POR ERROR BORRE REGISTRO, COMO LO REGISTRO NUEVAMENTE? EN LA PANTALLA SALE REGISTRAR! MI CORREO ES : lcasinos@hotmail.com GRACIAS!
Mar 26, 2011 | Cell Phones
Tengo el problema q de mi portatil extensa 5230 series el encendido de la pantalla y el encendido del teclado me han quedado inutilizados, y no me deja utilizarlos en modo normal pido por favor un concejo...
Primero, se prende su computadora normalmente? Que hace su teclado cuando la computadora esta prendida? Hay algun error que aparece un su pantalla? Desde cuando tiene este problema? Installo algun programa antes de que pase este problema??
May 17, 2010 | Acer Computers & Internet
Instruction manual for DAEWOO ADP5000 WIRELESS PHONE MODEL
TENGO UN TELEFONO INALAMBRICO MODELO ADP 5000 Y AL CONECTARLO A LA BASE ME APERECE UN ERROR DICE SIN REGISTRAR Y NO SE QUE HACER. ME PUEDEN AYUDAR?
Jul 18, 2009 | Lands Phones
Lands Phones Logo
35 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
