Question about Mitsubishi VS-5075 50" Rear Projection Television
Pip only on screen
Mitsubishi VS-5075, the screen is white with a small picture at left. If I push pip on the remote it goes dark, push it again and I get the small picture on left side. I've been through the menu and can't get the full picture back. Can you please help?
    Genius:
  • 1,694 Answers
Try hard reset first==Unplug ac cord overnight, then try again.Possible signal board trouble-- Practice visual acuity technique==look for CRT coolant leak on circuit board. Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Posted on Sep 26, 2007
SOURCE:
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Pip
ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
Sep 21, 2007 | Mitsubishi VS-5075 50" Rear Projection...
How do you to turn off the pip feature on a Mitsubishi VS-60603 tv remote control?
hello on the remote control the should be a button half black and half white this is the pip button good
luck
shaun
Oct 03, 2009 | Mitsubishi VS-60603 60" Rear Projection...
I HAVE SOUND BUT NO PICTURE
Is it a rear projection tv? plasma? or LCD?
Feb 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-50707 50 in. Rear Projection...
There is a quick test you can do to determine if the problem is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video. The PIP module has surface mount capacitors that go bad. Just make sure you solder a small lentgh of wire to the capacitor leads to prevent them from shorting as they cross over each other. Just plug the wires into the socket no need to solder them.
Mar 08, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Jitter and tearing on bright pictures
1. VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Jan 21, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Foot note to issue
If the source to the PIP input is a color signal then the PIP display will be color. PIP sets have two video sources one goes to the main screen while the other goes to the PIP. it all depends on what the format of the signal is being sent to each input. This is quite normal.
Jun 29, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Main screen color seems overmodulating. PIP subfeed color fine. White like under black light.
rule number one about all vs chassis with vertical can pip boards take them out and throw them away i could fix one but you couldnt beleive me and it wouldnt be worth your while do a search on your modle number until you come up with instructions on how to add two caps to the pip board connector to bypass it until you do this you are wasting your time Mitsubishi ... we're still building Zeros
Dec 08, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
