Question about Garden
I AM NOT GETTING FIRE TO THE #8 AND #5 PLUG WIRE ON A 1964 283 SMALL BLOCK THAT HAS BEEN CONVERTED TO ELECTRONIC IGNITION
    Sergeant:
  • 416 Answers
8 and 5 are directly across from each other on the dist. do you have the right firing order? 18436572 chech the cap and rotor inside be sure bolts or clips are secure
Posted on Oct 17, 2013
  • 54 Answers
Are you checking at the Dist Cap or spark plug end of plug wire ?
If you are checking at the plug end of wire try exchanging that wire with a working wire. If the problem is not there with other good wire the wire must be bad. If it is not the plug wires to #8 & #5 replace DIST CAP. The Cap must be cracked or arcing internally.
Posted on Oct 16, 2013
2 Suggested Answers
  • 640 Answers
SOURCE: I have a craftsman 6
Coil and spark plug wire all that's left.
Posted on Jul 24, 2011
Gx610 Honda v-twin small engine one side want fire
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
Feb 05, 2017 | Honda Vehicle Parts & Accessories
Cant get spark on 1995 yamaha 400 kodiak testing electrical parts cant get spark to spark plugs
Check the engine block ground strap or ground wire. Does the plug fire when held close to the block?
Feb 21, 2015 | Dual-Fire Ignition Coil Kit
Hi my 2005 NP DID Pajero had a problem with the starter motor which i've replaced with a new one. The engine is turning perfect now but the engine wont fire! Would anyone be able to help me and suggest a...
Although more info would be helpful, the first thing that comes to mind
is that, somehow, the power to to ignition system was disconnected
when the starter was installed. Easy to check... take off a spark plug
wire at the spark plug, put a small piece of wire in the end, and place
this 1/4 inch away from engine block... be sure there is no gasoline or
gas fumes near. Have someone crank the engine and look for spark
from the plug wire to the block. If no spark, may well be the ignition
system (do this in shaded area so you can see the spark). If you have
spark, then the problem is elsewhere.
Jul 27, 2014 | Cars & Trucks
Will not start... Getting fuel but I think no fire
sounds similar to an issue i had... have you recently changed the fuel filter? if so, what about spark plug wise? check the ignition coil (remove plug wire from cap and place metal bit at least 1/8" from engine block and have someone start car for a sec caution stay away from cable when doing this) if spark occurs it could possibly be the pickup coil located within distributor however this coil can cost just as much as a new distributor so just get one from junkyard
Sep 19, 2012 | Cars & Trucks
2009 electra Glide Classic rear cylinder doesn't spark its not the coil or wire
Hi D, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially "GROUND" cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below. Good luck and have nice day. Harley Diagnostic Codes 04 to Present
May 24, 2012 | 2009 Harley Davidson FLHTC Electra Glide...
I put a new long block in my 1997 Chev truck 1500 4.3L Vortec. I am not getting any spark from my coil to my distributor. What tells my coil to fire? And where do I check it?
If you have a distributor then it is the one that tells the coil when to fire then it distributesb to the correct plug. What you do not have is ignition power, be it manual or electronic ignition. Check for that. A picture of your ignition system or deeper description would help.
Sep 07, 2011 | 1989 Chevrolet S-10 Blazer
Firing order on a 305 on the cap. Got the wires all messed up...
This method is good for the firing order on all chevy small block v8 engines from 265 cubic inches to 400 cubic inches. This would include 265, 283, 305, 327, 350, 400 cu. in. chevy small block v8 engines.
Let's cover some safety concerns first. If you try to troubleshoot a mixed up firing order with the engine running, you could be in for a serious shock,.. literally. You can do it, with certain precautions, but you really don't need to check the firing order with the engine running. You definitely don't want to try checking the firing order if you are wearing any kind of pacemaker or sensitive electromechanical prosthesis. The voltage coming out of the ignition coil is in the thousands. Common sense dictates that you wouldn't stick a knife in an electrical outlet, so you wouldn't want to take chances with being shocked by the electrical discharge from your classic chevy's ignition coil either. See the diagram:
The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
On classic chevy small block engines that use ignition breaker points instead of electronic ignitions, the number one cylinder is the one immediately clockwise of the small metal sash cover on the distributor cap. The firing order starts here. There is no sash cover on the distributor cap for GM HEI electronic ignitions, and the firing order is the same, but starting at the 5:30 position.
The firing order makes sense if you know how the cylinders are numbered. The number one cylinder is the front most on the drivers side and 2 being the front most on the passenger side. From front to back, the cylinders are odd numbered on the drivers side, and even numbered on the passenger side.
Additional details HERE.
Hope helps (remmeber rated this).
Jul 12, 2010 | Cars & Trucks
I took of*** my spark plug wires working on my small block 350 pickup and I don't remember the the firing order to put the new wires back on. Is there a diagram anywhere or is it even that difficult to...
Next time number each lead before you remove it and no. the dissy cap as well
See the diagram; Click to open a printable larger image in a new window. The firing order starts with the number one cylinder. We would connect the number one spark plug wire to the distributor cap terminal in the 6:30 position. distributor.pngSince the next cylinder in the firing order is 8 (passenger side rear), we connect the number 8 spark plug wire to the next distributor cap terminal (approximately 7:30 position) in the clockwise direction from number one. You need to be sure you continue the firing order in the clockwise direction around the chevy small block distributor cap from the last installed spark plug wire. Setting the rest of the firing order is just a matter of repetition. Be sure to count the spark plugs from front to back on each side of the motor to identify the correct cylinder number in the firing order.
Jun 21, 2010 | Cars & Trucks
The car will run for 10 to 15 min then die then 5 to 10 min after it dies it will start again. it has the 6 cyl
I've seen this with several vehicles within the mid 90s (including a 95 probe) and traced it back each time to the electronic ignition. As the car drives, the ignition coil heats up and becomes more resistive. As this happens, the coil outputs less voltage until finally it's not enough to put out sufficient spark to fire the cylinders.
Try this: Drive the car around for a while. When you start feeling the motor struggle, park somewhere and idle until it dies. Then quickly pop the hood, pull an ignition wire, pop in an extra plug and hold near the block (check for fuel leaks first!!) and observe the spark strength. If it looks weak, a new electronic ignition unit will solve your problem.
Jul 26, 2009 | 1994 Ford Probe
Why do I keep getting current to this
check to see if you are getting fuel and fire if you are getting fuel ,plug a spark plug put wire on it lay close to metal on engine check for spark, dont get near gas, cause a fire, if you are getting fuel and fire should crank,hope to help you,robert b.
Jun 18, 2009 | 2004 Chevrolet Silverado 2500HD
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
