Question about Kitchen Ranges
Mer5752baw When try to bake and set temp, then hit bake. It goes right to the temp add beeps like it is there, but does not get hot at all
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
The oven temp sensor is bad and needs to be replaced. Here is the part to order.
Posted on Oct 21, 2013
  • 126 Answers
SOURCE: digital oven pops breaker as oven starts to light
You have a direct short. A wire or component has touched ground .Gas or electric?electric check connections at bake and broil elements in back.Gas look for broken wire /connection at ignitor or ERC ,(control board)
Posted on Jun 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a Maytag model MER5775QAW free standing
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
Posted on Nov 09, 2009
SOURCE: KitchenAid gas range superba not reaching/registering right temp.
kitchenaid superba electric double oven "takes too long to heat up"
Posted on Dec 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - Model Number removed by
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Posted on Jan 03, 2010
SOURCE: oven temp
I am experiencing the exact same problem. May try to trouble shoot myself if no one provides assistance on this site. It looks like the problem has to do with either the Sensor, Heating Element or etc..
Posted on Jul 03, 2010
My ibm wheelwriter beeps 1 time when i tab
Does anything else work? It is possible your right margin is set to close to the left margin. Try tabbing all the way to the right, set the right margin, hit the return and then hit the tab. If it beeps and goes all the way to the right, try setting some tab stops and retry the test.
Jan 06, 2014 | IBM Office Equipment & Supplies
I set oven temp. It seems to heat ok, during the bake cycle it beeps then shuts off, no display for oven function but the time display remains. Replaced the relay/display board but same.
the beeping is probably saying that set temp is reached just probably oven is still heating so dont turn it off look after an hour if it still on and very hot and worry about display changing its probably how the programmer wanted it to be
Aug 08, 2013 | Kitchen Ranges
Rf367lxss oven temp low need to adjust rca whirlpool
MOST OVENS ARE ADJUSTABLE TURN ON BAKE, ADJUST TEMP ALL THE WAY UP AS HOT AS IT GOES, HOLD BAKE BUTTON DOWN UNTIL IT BEEPS AND REGISTERS 0. THEN ADJUST TEMP UP IN 5 DEG INCREMENTS.GOOD LUCK!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 21, 2010 | Whirlpool Ovens
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
Jan 03, 2010 | GE Kitchen Ranges
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not heat to right temp
you can calibrate you oven try presiing and holding the bake button for 3-5 secs. it should beep and put a 00 in the display. using the temp up or down arrows you should be able to adjust ther temp to a max of 35 degrees + or -. after setting to desird 25 presss start and that setting will be ingrained in the memory forever(or until you change it again)power failure will not effect it either . of that doesnt work gimme the modle and ill ck further
Mar 08, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
