Need to replace the computer board. How do I get to it?
  • 62 Answers
What model ?? what make??
Posted on Oct 16, 2013
Rock-Ola 498 Carousel wont spin but turntable does
Step 1- Make sure that the computer is booting up. It should have ONLY (1) LED LIT either "Normal Operation" OR "Default Pricing".. If you have anything else here, then you may have a computer problem OR a power supply problem.
NOTICE - The computer can act strange if the battery is dead.
Important - There is a 3.6v NiCd battery located in the computer. It WILL eventually cause corrosion of the circuit board, causing permanent damage. I recomend that you remove the battery from the board and install any 3.6v cordless phone battery here. Make sure you get a NiCd and NOT A LITHIUM ION. Solder the (new) battery wires to the board making sure the soldered connection goes through to both sides of the board. Use double sided (foam) tape to secure the battery to the board. (REMEMBER POLARITY IS VERY IMPORTANT)
If you're booting OK go to step 2.
Step 2 - Make sure that the Opto board's LED is flashing while the mech is scanning. If not then you have a problem there. The opto board may need adjusted or cleaned. Make sure there is not a ball of fuzz blocking the sensor window. This board is located on the right side of the record basket. You will have to look UNDER the board while the mech is scanning to see if it is flashing. If it's flashing, go to step 3.
Step 3- Replace the (2) 22uf tantalum capacitors on the mechanism control board. It is located below the turn table. The yellow ones (caps) often fail. You can use a regular electrolytic caps. Be aware of the polarity when replacing these (Very Important). As you can see one was already replaced here.14cfa94e-c3a0-4c2e-b0ba-c13c73109f07.jpg
The mechanism control board. is located be beneath the turntable (see below)
This last pic may help you if you need to confirm the polarity of these caps.
If the problem is still present, you may have additional problems with either this board, the power supply, or perhaps the computer has too much corrosion. At this point you would need to to have schematics and then see if you have the 5 volts on the regulator transistor. (really a chip). I have found one of the little blue 0.1uf capacitors (at the transistor) SHORTED,causing the regulator to do nothing. Check these caps before you order a new regulator. If you confirm all of the voltages are correct. You will need to re-visit the the mechanism control board, saving the computer for last.
If at any point you feel "LOST", you should consult a technician.
edward_gardner@rocketmail.com
Dec 22, 2013 | Wurlitzer Jukebox 1015 One More Time...
Need layout of the C521 motherboard where is the BIOS password reset
Hello Brenda,
Click the link below to download the Dimension C521 Service Manual.
C521 Service Manual Clearing Password Settings
  1. Turn off the computer.
  2. Disconnect any telephone or telecommunication lines from the computer.
  3. Disconnect the computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
    To guard against electrical shock, always unplug the computer from the electrical outlet before removing the cover.
  4. Remove the computer cover.
  5. Locate the 2-pin password jumper (PSWD) on the system board and attach it to pins 1 and 2 to clear the password.
    When the computer ships from the factory, the jumper plug is attached to pin 1.
  6. Replace the computer cover.
  7. Connect the computer and monitor to electrical outlets and then turn them on.
  8. After the Microsoft Windows desktop appears on the computer, shut it down.
  9. Turn off the monitor and disconnect it from the electrical outlet.
  10. Disconnect the computer power cable from the electrical outlet, then press the power button to ground the system board.
  11. Remove the computer cover.
  12. Locate the 2-pin password jumper (PSWD) on the system board and attach it to pin 1 to re-enable the password feature.
  13. Replace the computer cover.
  14. Connect the computer and devices to electrical outlets and then turn them on.
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
    Follow Dell on Twitter @dellcares
Mar 28, 2013 | Dell Dimension C521 PC Desktop
FPD 2485W .I replaced the bad capaitors in the inverter board, I hear the sound but can not see the gateway logo. I hook it up to the computer a d I do not see any video. Replace the inverter board, power...
Sounds like you've replaced everything but the backlight itself!
If you have another working unit, connect this LCD panel to the working unit and see if it works. If it's still dark, you need to replace the FL tube (backlight(s) ).
Jul 31, 2011 | Gateway FPD1950
My monitors7540 sow menu and blinks frequently
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 18, 2010 | HP S7540 17" CRT Monitor
Nokia 800+ monitor - screen is blinking approx.
Take care.
Jul 17, 2010 | Nokia 800 PRO+ Monitor
My oven locked and I cannot open it nore turn off the lock. The temperature went down and it's been locked throughout the whole day does anyone know whow to fix the problem?
Unplug the power from the OVEN for 24 hours and let the remaining voltage in the circuit board REBOOT the computer.
It should work fine then, or you will need to replace the computer board. It is an easy fix. Replace the Auto Lock Switch too, just to be safe if it was the item that toasted the computer board.
Good luck,
Jim
Dec 21, 2009 | Ovens
Kenmore oasis washer. Code f1 on computer comes up. Do I need new computer board?
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Oct 14, 2009 | Kenmore Washing Machines
Need to replace my Asus A8N-LA motherboard. fan controlers gone
If I were you, I would replace the motherboard with the same model as Hp use´s...
When you try to find another compatible board you will have some problems due to exclusive computer case..sometimes you need to adapt things...too bad...it´s better to repair with original board....
Sep 09, 2009 | ASUS A8N-E Motherboard
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
