Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
I have a kenmore upright freezer . its not cooling down . the expert came and told me the fan is not working . where can i buy the fan ? can i buy fro the store ? I need it faster .
    Master:
  • 492 Answers
No you have to order through part number from any online supplier of parts for that model. Just google freezer parts and look up part number.
Posted on Oct 18, 2013
  • 54 Answers
Check your phone book for Sears Appliance Repair and Parts.
Or call your local Sears Store for information.
Posted on Oct 16, 2013
Mij20
  • 4 Answers
SOURCE: kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Posted on Aug 26, 2007
SOURCE: kenmore 15 upright freezer
feel the fan motor to see if it is hot. If it is the fan motor is shot. Hope this helps.
Posted on Sep 26, 2008
mikeh77586
  • 9 Answers
SOURCE: Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
Posted on Nov 12, 2008
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Managemylife com sears
You have a Kenmore upright, which you set on ZERO? WHY?
Every time you open the door all of the cold air falls out and it has to start over in the cool down cycle, the fan stops to NOT push all of the COLD out while the door is open - you should consult a professional. Not for the freezer, for your ability to understand.
Aug 18, 2014 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Freezer smells hot and sides are hot
Check behind freezer , to make sure the fan which cools the compressor , is working . If not , replace the fan motor , or , something may be blocking the fan blade ( paper , plastic , etc ) .
Sep 12, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Fan
You should be able to hear the fan if it is on (inside ) .If the compressor is running , then the fan inside the freezer should also be running .
Jul 19, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Mar 21, 2009 | Kenmore Freezers
14.1 upright Kenmore freezer was unplugged to clean after hurricane. We moved freezer to new location, never turning it on its side...plugged in and light works but freezer is not cooling. There are no...
Check to see if there is a reset on the compressor or close to it. Turn your control knobs up and down and see if you hear a "click". You might cause it to engage at that point. Let me know how this does.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1999 Kenmore upright freezer alarm lite on, how to diagnose problem. Sealed unit and see no fan by compressor? Lower coiles seemed cold w/ some ice but higher shelves(coils) not so cold? 23 year Master...
the reason there is no fan on the outside is because the outer shell of the unit is the condenser. the unit does it have a fan on the inside? also how does that gfasaket on the outside of the door look like? let me lknow
Jan 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 15 upright freezer
Jul 28, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
110 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
