Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Go Go scooter wont engage gears - Pride Go-Go Ultra X 3-Wheel Travel Scooter
  • 23 Answers
Try first without power to switch from freewheel to engaged. Its usually a small lever on the back by the wheels. If the scooter can be moved by hand its in freewheel. Switch the lever then move the scooter slightly til you hear it click in. They don't have brakes, They are supposed to live in gear and then are either moving or not. :) Hope this helps.
Posted on Oct 22, 2013
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
What is the main cause of un passing electric to start
Hi, Bijualexander and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
50CC Scooter Wont start
How To Fix Scooter Starting Issues Part 1 Quick Guide
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
50cc scooter wont start need help
Scooter won start
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 26, 2014 | Bajaj Motorcycles
Scooter beeps and won't go. Gear doesn't click into "engaged" mode sometimes. It seems to slip between "engaged" and "freewheel".
sounds to me like the starter solenoid that's what I would replce first , then look towards new battery's if that fails .
Mar 28, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Gears not engaging properly
If it is the typical worn motor and the scooter is over 5 years old you are better off buying a new scooter.
Gears rarely go bad unless they were overloaded. It's usually the motor that wears out and is intermittent before it goes.
Oct 16, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My REVO is stuck in gear and wont go into neutral. Athough the lever does move to neutral. What could be worng?
My dad's Revo had the same problem. What happened was the little piston that the engage the gear is stuck and when you pull the lever to dis-engage the gear to neutral the piston stuck no matter how much force you use. What I did was take a flat head screw driver and can to WD40, spray some WD40 directly on to the piston let it sit for 10 second the WD40 to penetrate, then take a flat head screw driver try to lift the piston to dis-engage while pulling the lever up. You will need to remove the left wheel to see the clutch assembly. Good luck.
Aug 09, 2011 | Pride Health & Beauty
Starter motor just whines and wont start
Hi, Rayanthony19 the starter drive/Bendix is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day. Archived Scooter Startup Questions Won Start at All http://www.apriliaforum.com/forums/showthread.php?280275-2003-Derbi-GPR50-Starter-Motor-issues
Scooter Troubleshooting Scooter won start All about Scooters
http://www.49ccscoot.com/manuals/Derbi_Scooter_Manual.pdf
https://www.oemmotorparts.com/oem2.asp?M=Derbi
Feb 22, 2011 | Derbi Cross city Motorcycles
When i spin the wheel on my scooter back or fowards there is a sound of knocking but only when changing diections it only clanks wen it engages the hub if you know wat i mean thanks paris it is a...
This is normal. A slider gear engages into rectangular slots in a drive gear. The slots allow the dogs easy engagement into gear. The knock you are hearing is the engaging dogs striking each end of the driven gear. Please rate my answer, thanks.
Aug 25, 2010 | Yamaha YZF-R125 Motorcycles
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
80 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
