Question about Kubota Garden
How do you replace the tension spring on kubota 1860
I need help to change rubber tracks on my KUBOTA digger KX 021 ...PLEASE ?
you will have to open the small access door on the side of the track carriage and remove the fitting on the tension cylinder. this will allow the cylinder to back off and give you room to lever the track into place. once the track is in place put the fitting back in and pump it full of grease until you have proper tension.
Oct 25, 2016 | Kubota Garden
Need the wiring diagram to Kubota TG 1860,specifically to engage blade
You will need to contact the dealer on this, the diagrams are in sections maybe he will copy it for you.
Jun 14, 2016 | Kubota Garden
This is Kubota L4150DT tractor. the Brakes are wet brakes. that need replaced. could I please get a free PDF repair manual. that shows how to replace the wet brakes.thanks
Hi Simon I googled (user manual for kubota l4150dt) and got this links below, The manual you're looking for ranges in price from $9.95 to $95.00 I didn't see any free downloads, I also noticed the manual you're looking for has 4 model number in it L3350, L3750, L4150, L4150-n... Hope you find what you're looking for..CHEERS..
https://www.google.com.au/search?q=Kubota+L4150DT+tractor&oq=Kubota+L4150DT+tractor&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8#q=user+manual+for+Kubota+L4150DT+tractor&start=0
Mar 25, 2016 | Kubota Garden
Repair tension spring
Is this the upper thread tension spring? In most instances it is replace rather than repair. A good service manual or youtube search can provide instructions on how to take apart the tension assembly and replace the spring with a new one.
Jan 01, 2015 | Sewing Machines
Do you have free manuals of Kubota mowers?
Try requesting manuals directly from Kubota.
Jul 16, 2014 | Kubota Garden
Kubota T1570 transmission will not engage in forward or reverse. Starts fine and runs fine, mower blades engage, but no movement. Worked yesterday, not working today. Any ideas? Thank you.
Only problems that come to mind are rather obvious ones. My first guess would be a broken HST belt- the one from the engine to transmission- OR part of that belt assembly (idler pulley, slipped off a pulley, broken tension spring). Another possibility would be the pedal linkage. Maybe a pin fell out of that somewhere and the linkage isn't engaging the transmission.
Oct 27, 2013 | Kubota Garden
Spring tension
should be able to freely slide a business card through the coils when belt spring tension is correct
Oct 16, 2013 | Kubota Garden
My kubota motor cord wont turn over when I pull the cord, it is stuck
you need to undo the pull cord spring and check if the spring on the recoil is broken. replace
Sep 30, 2013 | Multiquip Da7000ssa-1 Generator Kubota...
Vt500 c ticking sound. Cam chain tensioners pretty sure its the cam chain tensioner springs. lost their spring If its been making this noise for a while what else would i need to replace. cam...
You have a self adjusting cam chain tensioner. It is sold as an assembly. Take out the complete unit and replace it with a new one. The springs are not bad , the device that keeps the pressure on the tensioner is slipping causing a ticking sound.
May 16, 2010 | 1985 Honda VT 500 C Shadow
Garden Logo
63 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
