When I press power button the power light flashes once that's it' it is charging and the battery light is on its a dell 1540
  • 241 Answers
Many possible causes for this problem. To troubleshoot, first remove the power cord and the battery. Hold down the power button for 30 seconds. This will drain all energy from the laptop and create a fresh startup. If that doesn't let it start, remove the RAM and harddrive and try to start. It should partially boot and give you error messages. That would be good since you don't have a drive or RAM. If it doesn't do anything, you have a bad motherboard, a rather expensive repair.
Posted on Oct 17, 2013
2 Suggested Answers
jepito
  • 216 Answers
SOURCE: I have a Dell Inspiron 1525 that won't start.
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Posted on Dec 27, 2009
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Hi i am using dell latitude d600 problem with charging the battery 3 or 4 time orange light flash n 1 time green light . im unable to use my laptop with battery it working well with A.C power
Try to perform power drain. Take out the battery unplug the power adapter then press and hold the power button for 30secs. Put the battery back in then plugin in the power adapter then turn on the computer. If same issue occur, then you need to replace your battery.
May 18, 2010 | Dell Latitude D600 Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Will not power on once chager is plugged in lights flash three times but there is nothing
what lights flashed? is it the LED locks or the battery light? try to run PSa. press andhold the fn key and pree the power button and release button at the same time when you see the dell logo screen
Oct 01, 2009 | Dell Inspiron 1000 Notebook
Laptop will not boot. The power light flashes
CLICK HERE
the codes which you see are universal for all the dell laptops. find the appropriate. this will solve your purpose and guide you how to go furthur.
Sep 26, 2009 | Dell Inspiron 1521 Laptop
This started last night, my battery indicator
The red or amber flashing lights indicate a bad battery. The Dell battery warranty is only for one year and the D600 has been out for a number of years. You should replace the battery. You can use the laptop as it is as long as it is connected to AC power.
There are several places to buy replacement batteries. One is www.bixcomputers.com. If you do a search on the web you should be able to find other sources.
Good luck and I hope this helps, even if it isn't good news.
Feb 28, 2009 | Dell Latitude D600 Notebook
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
