Question about Maytag M6Y12F2A Air Conditioner
I have ducted o-general wall-mounted controller clock flashing EE:EE then after getting error 25:00
Flashing EE:EE on airconditioner wall control
your system might need reseting look for a reset switch on your thermostat or your inside unit usually means dirty filter
Jan 04, 2013 | Heating & Cooling
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
White maytag gas and broiler wall oven is flashing F 7, what does it mean?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
We have ducted air which cuts out and shows on the control panel where the clock is says EE.EE
When EE:EE is displayed on remotecontrol , press "Energy Save" &"Zone Control" buttons simultaneouslyfor longer than 3 secs. The error code will then be displayed on the LCD.Then write again. Thanks.
Jan 31, 2011 | Fujitsu Heating & Cooling
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
FUJITSU AIR CON
fujitsu tech line # 866-952-8324 very good ac dan
Aug 01, 2008 | Fujitsu Heating & Cooling
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Feb 24, 2008 | Heating & Cooling
Maytag M6Y12F2A Air Conditioner Logo
37 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
