I've checked all of the connections and also changed cables but the printer box continues to say printer off line, It worked perfectly yesterday.... and nothing has changed between then and now. Need to print ASAP for a show!!!
  • Daniel Hayward
    Daniel Hayward Oct 16, 2013
    I've also tried 2 macs and neither gets a hot printer connection.
    Habit-Forming:
  • 193 Answers
You need to post more info on your system type before any one can help if it is windows the problem lies in device and printer setting page in their you will see your default printer and also it will state if it is on line or not
Posted on Oct 16, 2013
4 Suggested Answers
SOURCE: "Off-line" error message
Go to control panel - printers. Right click your printer icon - select delete printer. Reinstall the software and drivers via CD supplied. May have to restart your computer when complete. Go back to control panel - select printers - select add a printer and follow the instructions. When finished print a test page.
Posted on Nov 07, 2008
  • 55 Answers
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Posted on Jun 30, 2009
  • 33 Answers
SOURCE: Unable to clean error message
just swith of the printer even the swich of the main switch where the printer's plug is connected wait for 40 second then power it on again it will start working again if everything is connected perfactly
Posted on May 07, 2010
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
My panasonic viera has just stopped working. I can play a dvd but not watch tv, It says no signal. I have checked all leads and none are loose. It worked yesterday!! What is wrong with it? Please help
What is your TV source? Is it OTA, cable or satellite? Do you use a set top box or a direct coax cable connection? If you have OTA, what antenna do you use?
Try the following depending on your setup:
For all, check if a lightning/surge protector has taken a surge and needs to be replaced. These are placed in the coaxial line to divert a surge that could destroy your electronics. Also try replacing the cables. Check exposed cable for damage.
For OTA, first check that your antenna is oriented to point to the transmitters in your area. (Outside antennas will sometimes turn in the wind; indoor ones can be bumped.) Try a new coaxial cable. If the antenna has an amplifier (or you use a splitter with or without an amplifier), try connecting the cable directly without the device. I've had several amplifiers fail and turn into signal filters (blocking all of the signal).
For any system with a set top box, make sure that the box is on. For satellite, make sure that your dish hasn't moved out of alignment.
To check if it is the Viera TV tuner or the incoming signal, try another TV at the same connection. If you have cable and another TV gets no signal directly connected to your incoming connection, you may need the company to fix the incoming cable. (Underground cables can be damaged by rodents or neighbors who dig without checking for utilities.)
I hope this helps.
Dec 21, 2011 | Televison & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
Dear sir, i have printer hp laserjet p1102 , yesterday i could print with this printer corecteally but now when i try use this printer the red light on and the green light off.the printer came error, can...
Dear,
You can do one thing, if possible for open printe and check whether power ping is perfectly attahced to logic board and you have cable inside printer attached to from catriges to login board,
just check cable or change that data cable.
Mar 04, 2011 | Office Equipment & Supplies
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Unable to print to HP3055 connected through network. Has orange light on the back. All of the lights on netgear switch going crazy, but go normal if I unplug HP3055. Worked perfectly until yesterday when...
check the cable with cable tester ensure good or try with another cable
there is an ip address setting pls check it
if the printer in warranty period try with hp
Jul 15, 2009 | HP LaserJet 3055 All-In-One Printer
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Epson Stylus C46 InkJet
Check USB cable.
Try different cable and connect it to different usb port.
If it is not the cable, do the following driver reinstall:
Disconnect printer from usb
Remove printer from 'installed printers' in Windows.
Install again driver from disk with printer not connected.
connect printer when required by setup procedure or after installing drivers.
If it still does not wark then the printer is faulty.
Jul 11, 2008 | Epson Stylus C46 InkJet Printer
18 people viewed this question
k24674
jasbo
jasbo
