Question about Hoover Vacuums
Cleaning solution runs out - Hoover Vacuums
    Scholar:
  • 161 Answers
Most of these units have a control switch as to how much solution you want as you are spraying. Use the lowest setting. When the unit is empty, then refill it of course. Make sure the unit is not leaking (check the solution container for leaks).
Posted on Oct 17, 2013
I need instructions on how to clean Digital Advantage Iron. I have lost my manual.
any iron can be cleaned by running a little water and vinegar through it several times, it loosens the scale build up that gets in all irons over time, be sure and try to clean out the venting steam holes in the face of the iron, Once you do this, run clean clear water through it and you should be fine, if possible, always use bottled water (purified) water in irons
Jun 02, 2011 | Vacuums
No soap is coming out of the wand
Most likely it is clogged with old detergent residue. These get plugged when the old solution sets in the line and dries out and hardens. you will need to clean the lines out, you may have to disconnest them and run hot wather thru them to clean out. Always run pure water through the attatchments and clean after using cleaning solution to clean out the lines before storing.
May 11, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Followed directions on filling water and solution tanks. When I use the cleaner the cleaning solution is not being dispensed.
The tubing is clogged, you need to take the tubing off and clean it out or some how force some hot water thru the tubing and clean it out. this happens when you don't run clean water thru thesystem after using the cleaning solution. The solution dries and hardens in the tube.
here is some other tips that should help you get it back up and running
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001755.pdf
Let me know if this is what you need or if you need more assistance
Nov 19, 2010 | Bissell 8910 ProHeat Clear View Upright...
My iRobot Roomba runs for about ten minutes, then shuts off. I can keep pushing the clean button and it will run for another ten minutes and stop again. Nothing seems to get clean.
Take the brush rolls out and you should see a copper disc. It is the dirt sensor. Clean it with Windex or some other cleaner. This works sometimes.
Sep 08, 2010 | iRobot Roomba 550 Vacuum
Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
My roomba 4150 is running very slow. It is fully
may need to clean inside.the wheels pick up trash and deposit it on and near motors.also try to take ends of roller brushes off and clean hair ect.
Jul 09, 2009 | iRobot 4150 Roomba Vacuum
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
Cleaning solution continually runs from clean solution tank
Where is the water running out? If at the bottom of the tank, is the seal on where the tank sits on, Maybe the rod inside the handle is staying pushed down, the reservior asm is bad, or a water line is off.
Feb 12, 2008 | Hoover F5881-900 Vacuum
Vacuums Logo
20 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
