Question about Broan NuTone 100HL Combination Bathroom Heater, Fan, and Light - Dire
Heating element Replaced the heating element twice in one year. any idea what the problem is?
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
Mira sport electric shower losing heat
It sounds like the heating element is going bad, needs replaced.
Dec 01, 2012 | Plumbing
Fridge works on gas...but not on AC
Your heater should measure 44 ohms, give or take 10%.
95 Ohms is way off. The RM2310 uses a 92 ohm heating element, perhaps you installed / were sold the wrong heating element?
Jul 15, 2010 | Dometic RM2652 Refrigerator
The fan oven is not heating up. The fan appears to to be operating and the element for the grill heats up . I had the oven element replaced over a year ago.
If the fan is working o/k, but there is no heat, then it is more than likely the element that has failed again.
The fact that you had it replaced a year ago, does not mean tha it will last a long tiime, it is quite common for them to fail in a relatively short space of time.
Take my advice and fit a new element.
Thankyou.
Dec 03, 2009 | Baumatic Ovens
Freezer keeps freezing up
You must change the defrost heater element, located in the back of the freezer compartment at the bottom. You have to remove the four screws, two on each side of the panel on the back wall of the freezer. The heating element located at the bottom has two wirers connected underneth on both sides of the element. The wires have female connectors which slide onto the male spades on the element, and can be easily removed. The single element heaters are now being replaced with a dual element heaters at the manufactures request. A refrigerator which I have repaired twice failed again when I replaced a single element with another single element heater after two years. I was informed only after a second trip to the same store to replace the part that General Electric suggested the dual element after they realized there were so many problems with the single element. I think G.E. should have factory recalled these units after they knew there was a problem. I also think I should not have to pay 38 dollars twice, and I should have been given the dual element the first time I had this problem!!!!!! I am a electronic and appliance technician and didn't have to pay for labor,But I am going to contacting G.E. about a refund for atleast one of my part replacements. I should been givin the dual element the first time. I recommend that anyone that reads this post that has had this problem do the same. My refrigerator was less than two years old when this problem first occured The dual element doesn't have to work as hard and will work much Longer!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 07, 2009 | General Electric GSS22JET Side by Side...
Heating element failed twice
most dryers have a thermal fuse on the exhaust it may be open
Mar 17, 2009 | Whirlpool LER5636P Electric Dryer
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Defrost element
you can check if the heating element has a metal cover on top. water should not be dropping on the glass directly while it is heating up. that is the cause of heating element blowing up. glowing hot glass cools down by a cold drop of water equals dissaster.
Feb 21, 2008 | GE GSH25JFR Side by Side Refrigerator
Heating elements
The upper element for AS690 is part# 512623
Thw lower element for AS690 is Part# 512624
Available at www.nelsonappliance.com/Toaster+Oven+Parts.html
or
http://abtecparts.com/delonghi_toaster_oven_elements.htm
Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
Broan NuTone 100HL Combination Bathroom Heater, Fan, and Light - Dire Logo
74 people viewed this question
Top Broan Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Broan Photography Expert? Answer questions, earn points and help others
