Question about ifrogz Audio Players & Recorders
My Ifrogz headphones only release sound through the right side? Started yesterday suddenly.
4 Suggested Answers
  • 537 Answers
SOURCE: No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Posted on Nov 21, 2007
  • 11800 Answers
SOURCE: I have the audio-technica Quiet
Each headphone is comprised of 2 parts: the shell (that houses the jack and the swivel post and the plate - to which the comfort pads are attached and on which the speaker is fixed. In this model the plate is glued to the shell so if you want to open it you will have to force it open - put a knife between the outer shell and the comfort layer covering the plate and slowly and methodically pry it open.
Posted on Nov 17, 2010
coldtoon
  • 51 Answers
SOURCE: The left ear of my
one or more of three things might have happen 1. the wire came off the speaker itself 2. the wire has been crushed in some part along the line in some shape or form 3. the wire came off the headphone jack in terms that it was built weak and ment to break to get you to buy more. In all three cases it just takes a bit of soldering and black tape.
Posted on Mar 03, 2011
The left side of my earphones randomly stopped working, can it be fixed?
Sounds like the wires are broken from stress or the mini jack is not inserted completely.
Jul 13, 2014 | ifrogz EarPollution CS40 Headphones
Toxix headphones sometimes only one side works
You can remove the soft bit on the headphones protectin the ear, after that you can remove the plasic inner covering with a very small phillips head screwdriver, then you can see the wires inside and figure out how to fix the problem.
Mar 24, 2014 | ifrogz Earpollution Toxix Headphones
Ear cushion is off the product at time of purchase
You can try returning the headphones to the store for replacement but if that doesn't work the cushion can be reinstalled unless it is damaged
May 31, 2013 | ifrogz EarPollution Plugz Headphones
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
No sound coming from iFrogz cs40 headphones Comfort series
No sound from yanked headphones:
Most likely cause is the litz wire has broken off internally from the loudspeaker of the corded entry side.
[1]: Remove ear cushions
[2]: Separate speaker-plate from headphone housing
[3]: Re-solder wire to speaker solder-tab.
The "Litz" wire may have broken behind its solderable bare copper part, in which case you mast clean the end before re-soldering.
The shellac varnish insulation can be scraped off a few mm with a craft knife, or flash-burnt with a flame.
If flash-burning, use pliers or dampened fingers to mask wire as varnish can flash back entire length.
Quite often, the leads are too short once broken, if manufacturer left little slack.
If this is the case, solder and insulate a short length of stranded intercom wire to extend the Litz.
Jan 17, 2018 | ifrogz EarPollution CS40 Headphones
I recently bought the Ifrogz earpollution cs40 headphones at walmart. I have been so far enjoying the headphones. However just days after I bought them, I found there was a problem in the jack. I think a...
It does sound as if the wire has been broken. I would suggest contacting the manufacturer to see if your product's damaged jack is covered under their warranty. They do have a limited warranty that covers defects in manufacturing and if this damage is something that just happened out of the blue and not from any other sort of activity that may have caused the issue, then you should be covered.
Aug 19, 2011 | ifrogz EarPollution CS40 Headphones
One of the ear buds on me ifrogz earpollution headphones just stopped playing music. I haven't been dragging them around or getting them wet or anything, and they're only a couple of months old. The other...
I had same problem. 1 of earphones stopped working. If i turn up volume, some sounds gets through, but then the other earphone would be blasting. Used them running so maybe sweat or earwax clogged them, but the problem didn't start until 1 month after stopped running.
Mar 07, 2011 | ifrogz EarPollution Plugz Headphones
The left ear of my ifrogz headphones stopped working! Please help!
Mar 03, 2011 | ifrogz EarPollution Plugz Headphones
I can't get sound to come out of the right earphone
Hi. Try to check if it is properly connected to the sound source. If it is, check for the wires. Look for damaged parts especially near the ends. If all these look fine then the earphone speaker itself is defective and that means you need a new pair.
Feb 04, 2011 | ifrogz EarPollution Plugz Headphones
Top ifrogz Audio Players & Recorders Experts
 Grubhead
Grubhead
Tom Chichester
Clive
Clive
Are you an ifrogz Audio Player and Recorder Expert? Answer questions, earn points and help others
