Question about Boating
Magneto Diagram - Boating
    Sergeant:
  • 456 Answers
For what
Posted on Oct 18, 2013
A wireing diagram for a wipace magneto assembly
The diagram may have to come from wipace.
Feb 06, 2017 | Garden
I hooked the battery cables up backwards and it blew the magneto hooked the cables back the right way and it blew the magneto again the model#21R707-0011 10.5hp 344c
This doesn't sound like a car, but more like a riding mower or something.
Anyway, is it the magneto that "blew" or a fuse for the magneto? You don't mention that you replaced the magneto....
Some manufacturers incorporate reverse protection diodes that are supposed to cause a fuse to blow if the battery is hooked up backward. Unfortunately, the diode often becomes a short circuit when this happens and would explain why a primary fuse would blow again, even when the battery is hooked up correctly. If you have a wiring diagram for what you're working on, I'd suggest checking for a diode connected near the battery cables. If you don't have a wiring diagram for this, you're probably going to need one.
Oct 15, 2016 | Cars & Trucks
Magneto ignition diagram
there is ablck grounding wire on it follow it to groun point
Aug 24, 2014 | Snapper Garden
Magneto wiring diagram
Most magneto systems have an external connection from the points. Grounding this kills the ignition.
May 20, 2014 | Boating
My pitbike 110 cable come lose out off cdi so bought new wiring kits but cant get it to spark need help were the wires go
this is cdi wiring plan. notice wires to coil, kill switch, 2 to magneto and earth the diagram link shows what the wires are. physically look to see which wire on bike goes to ht coil, the kill switch, 2 from magneto and earth or to from earth. hope it helps http://tboltusa.com/store/images/5_wire_Lifan_Wiring_041605_HI.jpg
Feb 15, 2013 | Motorcycles
Electrical wire?
Because of the simplicity of the ignition system, there really is no diagram necessary. Husqvarna uses a simple two-wire harness in that unit (e.g., p/n 544 08 28-01) that has two female quick-connects at one end and one female quick-connect and a ring terminal at the other end.
The end with the ring connector is the magneto end. The female quick-connect there attaches to the magneto primary circuit control terminal, and the ring terminal there is secured under the head of one of the two magneto armature mounting screws.
The opposite end of the harness goes to the ON/OFF switch on the case side near the handle. This switch is a simple single-pole/single-throw switch that allows the engine to run when in its open position, and kills the engine when in its closed position. The engine shut-down occurs through the effective action of grounding the magneto control terminal to the magneto armature frame, as accomplished through the circuit through the ON/OFF switch when that switch is closed.
To identify the armature, harness and switch for your saw, go to the Husqvarna Manuals Download Page for your saw, identify the list by the build date of your saw, and download the desired list. (I like the 2009-02 version as it has the sections identified and bookmarked, but be sure you ID the correct parts for your saw. It might help to DL your manual as well as the 2009-02 version for reference purposes.)
The armature and harness will be found on the Ignition / Flywheel page (items 7 & 8, respectively), and the switch will be found on the Air Filter / Intake / Carb and Air Purge / On-Off Switch pages, as item 9 (e.g., p/n 504 00 34-01, includes retainer bail).
If you are getting no spark from the plug wire when cranking the engine with the ON/OFF switch in its ON position, the problem must be in one of three places -- the magneto or its mounting, the harness, or the switch. A short between the magneto control terminal and the magneto armature will kill the spark, as will any short between the two wires in the harness. Similarly, an ON/OFF switch that fails to open (internally) will have the same effect as leaving the switch set to its OFF position.
If the engine will not stop when the ON/OFF switch is moved to its OFF position, an open magneto circuit is indicated. This can be due to a broken wire in the harness, a loose or corroded connection of the grounding (control) wire to the armature frame, a break in the magneto primary circuit to the control terminal, a loose or disconnected wire at the ON/OFF switch, or an ON/OFF switch that fails to close (internally).
While broken or shorted harness wires are easily repaired without replacement, any magneto or switch failures will usually require replacement of the failed component.
Jul 21, 2012 | Husqvarna 450 e-series 18" Chain Saw
1967 evinrude sport 4 60hp wiring diagram
That came with either battery or magneto. If the distributor is rather shallow and the ignition wires cross the middle of the cylinder head, it is battery, if the ignition is long and the wires cross above the thermostat housing- it is magneto.
That is one of the great historic motors made, but carry lots of gas!
Dec 12, 2011 | Clymer EvinrudeJohnson Outboard Shop...
Lawn mower will not start
There can be as many as 5 safety interlock or kill switches on these machines, Check for Blade engage switch, seat switch, deck level switch, low oil switch, and transmission/clutch switches. any one of these could be open or have broken or just unhooked wires, Magneto problems are rare unless they have been burned or broken. Ignition switch may be faulty or just dirty, but more likely you are dealing with a safety switch thats not in the "run" position. I can't help you with a wireing diagram but I'm sure someone out there can.
Good Luck.
Oct 27, 2009 | Garden
Tecumseh 8 hp tvm220
it is a standard magneto fired engine --- go on line and google up magneto
Jun 22, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
