Question about Kitchen Appliances - Others
Mix is not freezing on either side - Kitchen Appliances - Others
Why does my ugolini slush machine over freeze only on one side?
check your mix. if it's too lean (not enough syrup base), it'll freeze too quickly. if the auger stops moving when it's freezing, you blew a gear and it won't know when to stop freezing. also if the torque spring on the right side of the motor (through the back) is broken or missing, same thing.
Jun 27, 2014 | Kitchen Appliances - Others
How do i fix one side freezing much slower than the other?
it needs an ambient temp of 75-80 degrees to work well. to hot, it struggles and can't cool down. make sure you have at least 6 inches of space behind the machine so it can breathe, and clean the filter regularly. the mix has to have a brix level (water to sugar or "antifreeze" ratio) of about 12. to rich and it won't freeze. to lean and it'll ice up. alcohol brix is too high. you may also have a small refrigeration leak
May 09, 2014 | Bunn Kitchen Appliances - Others
How many gallons of antifreeze will it take ?
Anti freeze is mixed on a 50/50 basis. The coolant capacity varies so check the hand book for capacities and mix the anti freeze to water before adding to radiator. Drain radiator first so as not to mix different anti freeze products.
Nov 09, 2013 | 2005 Toyota Matrix
I have a 2 hopper bunn ultra 2, both sides are icing over on the outside
the mix is too rich. add some water to each side. it freezes based on torque, not temp.
Aug 17, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Soft serve machine freezing solid
POSSIBLE CAUSES• Mix hopper is empty, freezing cylinder starved for mix.• Mix in hopper contains ice particles, mix feed tube clogged.• Machine turned too cold
ACTION REQUIRED• Add mix to hopper. Put machine in wash mode to help thaw freezing cylinder.• Pull mix feed tube to fill freezing cylinder. Replace mix feed tube and put machine in wash mode to help thaw mix in freezing cylinder.• Follow manufacturer's recommendation for the proper temperature for the mix being used.
Apr 12, 2013 | Ice Cream Makers
Can I replace my dex coolant with regular antifreeze? in my 1997 chevy malibu and how
they say you cant mix different coolants but you can go to auto-zone etc, and buy a cheaper anti-freeze for general motors products. its a 50/50 mix for all gm cars and trucks.you can add this coolant to any brand of anti-freeze. its called universal type anti-freeze. to run a differant anti-freeze in it, you have to flush out complete engine and radiator because the dex-cool and the green stuff do not mix well and cause engine corrosion etc. dex-cool is reccomended for all chevy engines. good-day !
Sep 11, 2011 | Chevrolet Malibu Cars & Trucks
The left side of the machine is freezing, but it's pushing all of the frozen product to the top of the lid and overflowing
each side should only have 2 to 2 1/2 gallons of mix. there is a line on the bowl that is the max fill line. as it starts to freeze, the auger pushes the product to the front and up. if it's too full, it'll over flow. just empty some out.
Nov 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
What kind of antifreeze
I would check and see if the vehicle contains Dex-Cool, the orange anti-freeze, or the regular green type anti-freeze. They make an anti-freeze that will mix with either type. Don't mix the green and orange types.
Oct 27, 2010 | 1996 Isuzu Hombre
Can i mix water and anti freeze in my car
yes just pour in rougly equal amounts of water and coolant or use the ready mixed type avail at any auto parts store, the ratio is 50/50
Aug 25, 2010 | 1997 Plymouth Breeze
I need to know how much refrigerant to put in my 98 Ford Escort.
For 1998 Ford Escort 2.0L MFI SOHC SPI 4cyl
With AUTOMATISC TRANSMISSION
Cooling System Mix 7/8 Gallon (s) of Full Strength Anti-Freeze
Application:
With automatic transmission
Note :
Specification amount is for a 50/50 ratio
mix in the cooling system.
If using pre-mixed anti-freeze
double the amount needed.
With MANUAL TRANSMISSION
Cooling System Mix 3/4 Gallon (s) of Full Strength Anti-Freeze
Application:
With manual transmission
Note :
Hope this help (remember comment and rated this).
May 09, 2010 | 1998 Ford Escort
Kitchen Appliances - Others Logo
44 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
