Question about Microwave Ovens
What is error 13 on a rational oven - Microwave Ovens
What does E 13 mean on a Kenmore microwave oven?
Kenmore microwaves are made by several manufacturers. The E-13 error may indicate a humidity sensor issue or a problem with the control board. It could also be an issue with the wiring between the sensor and the control board. Try unplugging (or turning off the circuit breaker to) the microwave for at least 30 seconds. This may reset the error. If the problem recurs, the sensor or the control board may need to be replaced. Microwaves can store an enormous amount of power in the capacitor and may be dangerous. Repairs are best done by a professional.
I hope this helps.
(The E-13 code diagnostics above apply to Samsung-made microwaves.)
Mar 12, 2016 | Kenmore Microwave Ovens
What is SMH18165 -Error code: E-13?
It is a T1 maximum time error (oven did not preheat properly). usually caused by a failing thermistor/sensor, a bad seal, bad control circuit board or connector. Unless you are a really good electronics expert and have the test equipment for after-repairs microwave emission measurement, it has to be dealt by the service people.
Read more http://www.kgbanswers.com/on-a-samsung-over-the-range-microwave-what-does-the-code-e-13-mean/11020759#ixzz37XLvUOq8
Jul 09, 2014 | Samsung SMH9187ST Microwave Oven
WHAT is error 51 on a rational oven
Error 51 doesn't exist on SCC and SCC_WE models. If you are referring to a Combi-master or Combi-master Plus (CM or CMP) then error 51 means the battery on the control board is below 1.5 volts and should be replaced. Go to your local electronics or grocery store and buy a CR2032 battery, it looks like a quarter. Open up the front control panel and replace the battery.
Feb 26, 2013 | Microwave Ovens
Error code 13
All i kind find is it's a sensor error. turn it off or unplug for a few seconds then switch on again. if the fault is persistent it will need an engineer to look at it. is it under it's 12 month guarantee still?
Jan 13, 2013 | Samsung SMH9187ST Microwave Oven
Rational oven users manual
Plz specify the product model no. to get specific manual.
Thanx
Aug 26, 2011 | Microwave Ovens
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
My Samsung microwave model SMH7187STG 1.65 KW is showing error message E-13
E-13 T1 Max time error (oven did not preheat properly). This can be due to improper power line voltage, a failing thermistor, a bad damper seal, or possibly a faulty control circuit board. I would first verify proper operation with the manual, then if it still acts up and if it's in warranty, I would contact Samsung support. But if it's out of warranty and works okay otherwise, it may not be serious enough to worry about.
Hope this helps.
Oct 31, 2010 | Samsung Microwave Ovens
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
Microwave Ovens Logo
295 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
