Question about Acer Aspire Computers & Internet
Windows get back - Aspire Acer Computers & Internet
  • 247 Answers
If you want to repair or reload your Windows operating system, boot (start) your laptop with the Windows CD in the CD/DVD drive. the follow instructions on the screen.
Posted on Oct 17, 2013
How do I put the driver side power window back on track and the door panel for my 2003 Nissan Altima 3.5SE?
R/R the inner door panel, slide the window back on track, reconnect the window transmission to the window, (or reinstall the trans) bolt everything back together (window motor, window trans to door etc.) Make sure the window is in the UP position. use the switch to raise the window & keep it up if all is back together before finally installing the door panel ( make sure the switch & other plugs are plugged in before the door panel is reinstalled.) Lights etc. Good luck
Sep 14, 2014 | 2003 Nissan Altima
My back window wont roll back up. They are automatic and the other three still work fine.
It could be a faulty switch if not the window regulator or motor need to be replaced.
Nov 30, 2017 | 2006 Chrysler PT Cruiser
Rear window on my 2004 Tundra does not work any longer. Which fuse should I check?
Back window power comes from the 30A PWR 5 fuse in the driver side junction box (DSJB). It is applied directly to the back window relay. When the power main relay in rhe DSJB closes, 12V power flows through the 20A PWR 3 fuse and closes the back window relay causing power to be applied to the back window control relay and the back window control switch. that switch controls up-down motion. If the two fuses are OK, the two relays and motor can be checked for operation.
Sep 17, 2012 | Thule 2004 Toyota Tundra - Double cab -...
What's your problem?Is it possible to get my old windows 7 back after installing windows 7 ultimate & found to be snide how can I get my old windows back with no back up disk
Check your hard drive and see if there is a folder labeled windows.old
That is the old windows that was replaced by the new one. Click Start/My Computer and look on the C Local drive for windows.old
Then go to www.google.com and in the search box type: "how to restore windows.old" (without the quotes). Look for instructions from Microsoft site.
Here is a link below:
http://support.microsoft.com/kb/971760
Apr 07, 2012 | Samsung R519-53S Notebook
My rear defrost doesn't work. There is power to the switch but no power to the back window
check to see if power is coming out off switch to back window. if not switch is bad. try this if need be to find out if wire is broke. run a wire to back window from output on switch, touch or put it on defroster lug at back window. if it works then the main wire is bad, make sure all fuses and relays are ok. heres an eaiser way !! remove switch, jump from positive wire to wire going to back window. thats if wire is ok, to back window.
Feb 19, 2011 | 2000 Pontiac Sunfire
My oldsmobile Alero 2003 the rear window defroster does not work power to the switch but does not work on window
if no power from switch to back window, then it has to be the switch. if there is power to window, then it is in the back window defroster grid. its a possibility you have a bad wire or fuse, but check out power to back window first. have a good one !!
Dec 17, 2010 | 2003 Oldsmobile Alero
I have a 1996 mercury grand marquis and the rear defogger is not working. hat could be wrong?
Please rate. Thanks
could be the switch whcih incorporates a relay & timer.
Window, Heated Back NOTE: The radio antenna is integral to the window glass and is serviced with the back window glass (42006) as an assembly.
The heated back window consists of:
  • a series of grid lines baked on the inside surface of the back window glass and system wiring which includes heated back window ground wire (18C620) and heated back window feed wiring (18C619).
  • the grid lines, which consist of two layers. The first is brown as viewed from the exterior, and the second is silver as viewed from the interior.
Power for the back window glass defroster grids, the heated outside rear view mirror and the heated back window switch indicator is supplied from the power distribution box through a fuse HTD BLT (40 A)which protects the circuit.
Heated Back Window—Crown Victoria, Grand Marquis
Sep 18, 2009 | 1996 Mercury Grand Marquis
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
