Question about Sony KV-32FS12 32" TV
A 4 year old, a squirt gun, and my Sony TV!
So, it turns out that my Sony KV-32FS12 WEGA TV doesn't like being repeatedly squirted with water from my 4 year old's squirt gun. Apparently (based on the technical report from my wife), the TV started "freaking out", which with further interrogation, I determined to mean the Video Source kept cycling through all the sources. Also, it would not power off. After letting the TV dry for over a day, I tried it again with similar results. It will run okay for a little while, but then the video sources keep cycling. Also, during this "freaking out" phase, it will not accept input from a remote control. Being the rocket scientist that I am (no, really, I am!), I cracked the TV open and inspected the circuit boards for damage. I noticed water residue on the bottom of the main (biggest) CCA, on the leads for an integrated circuit with the part number 91A116HDF (1-431-851-11). There was also a little scorching around the edge of the component on the top side. So... my question is, would this apparently damaged component likely result in the behavior that I'm seeing. And, if so, where can I get another one of these integrated circuits? Thanks!!
    Genius:
  • 1,694 Answers
Stop!Clean area around all tactil switches and replace any that are defective.One or more of your function select switches up front is shorted---sending a continuous signal to the micro IC.Good,used switches are fine,but must have same physical parameters as originals.
Posted on Sep 26, 2007
SOURCE:
We have an 11 year old sony trinitron fv-32fs12 that is now getting a blue screen. I saw where there is a way to fix this using the remote control. Do you know how?
Blue screen means it's not getting a signal, so check your input setting. If it's set to TV and you're connected to a cable/satellite box then you probably have to put the set on channel 3 or 4. If you're set to AV1,2,3 etc make sure you have a good signal going to the input selected. I doubt that there's a problem with your TV.
Jul 10, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KV-32FS12 32" TV what is the weight on this TV set?
It weighs 165 pounds. Also, Width: 31.5 inches. Height: 27.88 inches. Depth: 23 inches.
Nov 28, 2009 | Sony KV-32FS12 32" TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY FD TRINITRON WEGA KV-32FS12
That generally means that the CRT is weak and is putting out low emmisions. This is confirmed by the fact that the color quality is not that great when you can see a picture IE: not enough red, green or blue. This is very common when these CRT's age.
Sep 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS12 32" TV Logo
350 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
