Question about Craftsman Garden
Not gettin spark - Craftsman Garden
    Sergeant:
    Champion:
  • 257 Answers
CHECK ALL SAFETY SWITCHES,,, IF ALL GOOD THEN COIL IS BAD
Posted on Oct 18, 2013
I have a 70 cc coolster dirt beike that wont start but its gettin fire,gas and has good compression
If its getting fuel, spark, and has good compression there's only two things left. Either no or very little air or a blocked exhaust.
Jan 03, 2015 | Motorcycles
Tl1000r wont start and plugs keep gettin wet
Is it sparking with known good spark plugs. If not you need iginition system diagnosis. If so you may have dirty injectors allowing them to leak or a bad fuel pressure regulator allowing too much fuel pressure causing the engine to flood.
Dec 30, 2012 | Suzuki Motorcycles
91 honda accord wont crank
There is a sensor under the left hand side of the dash that would not allow it to start, provided that you have replaced the electronic spark module inside the distributor first, which is what it sounds like it would be, When you say you replaced the distributor I assume you replaced it complete!
Jun 12, 2010 | 1991 Honda Accord
It starts and dies
if it starts then its gettin fuel,but it might not be gettin enough.or it might be gettin too much. after it starts and dies remove spark plug, if its wet then the saw is flooding out, try cleaning the plug and airfilter,u can also add some seafoam to the gas,it will help clean any dirt out of carb. if that dont help check the carbs diaphram
Apr 02, 2010 | RTO Spur Sprocket For Stihl 017, 021...
98`350 yamaha warrior elertic start
may want to chec fuse-sometimes a normal lookin one is bad-test inspect wiring in ignition system for corrosion-cuts plug wire could be bad or connect
Aug 20, 2009 | 2003 Yamaha YZ 250 F
Not starting
piston rings gone on piston or a gasket blown take spark plug off and put a compression tester in the hole and check the pressure goes over 100psi if not its good bye to rings buddy
Aug 07, 2009 | Cycling
Wont start ...not gettin gas
check the fuel filter and also check the fuse for the sending unit and all of the vaccum lines and the one behind the throttle body as well
Feb 23, 2009 | 1988 Chevrolet Cavalier Z24
Spark
I'm not gettin any spark it has a new rector firer any ideas ?need to check the coils first (rectifier ) is a voltage limiter and would not stop it from sparking.,,
Nov 10, 2008 | 2000 Cagiva River 500
Garden Logo
15 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
