Iomega 2 tb ego dead - Computers & Internet
    Novelist:
    Scholar:
  • 100 Answers
This is an external HDD, right ? In such case it's good to realise, such devices are a combination of an external USB enclosure and an internal SATA Harddisk. Maybe the harddisk is still OK, but the PCB (print with all tiny electronic components soldered at it) is defective. In such case you can overcome your problem by simply buying a new USB enclosure (even non-name will do) and put your harddisk in it.
To check if the harddisk is damaged, you should remove this by opening the Iomega casing and connect this disc inside a PC to it's motherboard. If the harddisc is working again, you're lucky. If not, than even the harddisk is damaged. If this is, and the data at your disc is important, you can try to source a identical harddisk (brand, type and productiondate) and transplant it's PCB. But, I can asure you, this last option is a tricky step.
Posted on Oct 18, 2013
  • 298 Answers
SOURCE: Windows XP stopped recongizing eGo
2 things... the USB port is bad, or the USB cable is too long and the HDD isn't getting a good signal.
1. Try another port and see if that works
2. Nip over to WalMart, Circuit City, Micro Center, PC World or Best Buy and get a shorter, Thicker USB cable of the same type - a cable which can provide the signal strength your ext HDD requires.
Also a possibility... The HDD may be 'lost' as Win cannot accept one of that size or the label/signature fell off and it is an orphan. It MUST have a driveletter, and it MUST have a special WIN signature byte on the HDD for it to work.
Bootup as normal, let everything get quiet, then plug in the ext HDD
Rt Click My Computer, Manage, Device Manager and in the Rt side, highlight the TOP icon. Then under Help, click the Computer with magnifying glass icon and wait. This forces your OS to 'Look' for any new devices.
When it finishes looking, look again under My Computer to see if your new HDD is now there. It will have to be formatted and have a driveletter for this part to work. Jump down to Disk Manager and see if it is there. You may have to Rt. Click and import it as a foreign drive or Rt click and give it a Driveletter ;-) If it is not, use a shorter, thicker (more wires) USB cable and try again.
Windows doesn't like Any HDD without win signatures on them - aka:'foreign disks' so ANY time this happens, if OS doesn't see it, use disk manager and Import it, then Rt click it and give it a Diskletter.
Posted on Jan 16, 2009
SOURCE: IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Posted on Feb 08, 2009
nonontech
  • 4737 Answers
SOURCE: How do I reformat my Iomega eGo hard drive so that
First of all, connect the Iomega to you mac, make sure it powers up and is detected by the Mac. Now follow these steps: ( It's important to note the Drive before you begin this task so that you may not make any mistakes.)
  • Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
  • Select the disk that needs to be formatted on the left.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to your Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on Feb 08, 2011
damneddle
  • 1607 Answers
SOURCE: Iomega Prestige 1 TB USB 20 Hard Drive I have not
Hello
Are the files inside the portable drives important? Or is it OK for you to lose the files as long as the portable drives will work again?
Posted on Aug 24, 2011
  • 121 Answers
SOURCE: I am trying to download a user manual for an
hello pmrollason, this is the link for Iomega product manual (locate at Iomega customer help): https://iomega-ap-en.custhelp.com/app/answers/detail/a_id/14432#hdde
find your product manual, then download.
hope this useful, regards.
Posted on Sep 01, 2011
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Mar 07, 2015 | Iomega Corp iomega eGo Helium 1TB 2.5"...
Do not Work!
I think if it's only damage to the power supply section of the portable hard drive, then what's on the disc might be OK. So it's just a case of taking the drive to somewhere that can fix the power supply side of the drive and hope that the disc can be saved.
May 31, 2013 | Iomega eGo Portable 35814 1 TB External...
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
Aug 25, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
My iomega eGO is not recognised by any pc. It used to work just fine. The small light doen't flash when plagged in. Help!
Looks like its dead, the only other thing I can think of is to try it on a pc which uses a linux based operating system instead of Windows.
Apr 06, 2011 | Iomega eGo Portable Hard drive 500 GB ...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
I have a iomega 160 ego the lights are on but it will not open or apear on pc what can i do
Take the hard disk out of that case, put it in another one and plug that in another pc. If it's the same then the disk is dead and all the data on it is lost. Junk it.
Sep 12, 2010 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
How can I open my iomega eGo portable
Carefully pry out the silver ends with a thin flat bladed screw driver. The ends are snapped onto the middle body section by one-way clips so you will probably break one or more of the retention clips. You are almost guaranteed to make cosmetic damage to the silver painted plastic ends though. You should only open it as a last resort ot get the disk drive out or possibly to salvage the SATA to USB controller board if the drive is dead.
Jul 17, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Hello. Can I use the iomega 250GB On Windows 98?
This device wont work with windows 98 its requires windows 2000 or higher, this is a link for the complete system requirements of this device http://www.buy.com/prod/iomega-250gb-ego-usb-2-0-portable-hard-drive-camo-iomega-ego-portable/q/loc/101/207899438.html
Hope that helps..............
Sep 15, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
