Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer, settings, nothing is working to get it to print normal.
    New Friend:
  • 16 Answers
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.HP Officejet 5610 All-In-One InkJet Printer - - 26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Posted on Oct 17, 2013
worldvet
  • 859 Answers
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
Posted on Sep 29, 2008
  • 31 Answers
SOURCE: Printer goes into super slow motion when printing .pdf's
Try this --- Double click printer>Choose Printer from menu bar>Select Properties>Click Advanced Tab and make sure "Spool print documents and Start printing immedialety is selected>Click Apply Button.
Posted on Feb 01, 2009
SOURCE: hp officejet 4355 is printing very very slow
get a new printer
Posted on May 05, 2009
  • 96 Answers
SOURCE: HP Laserjet 1200 prints pdf documents slow
pdf documents are historically slow, they usually depend on how they are created and how many attachments or upgrades have been added to the document. this accounts for some of the variations of speed the documents are printed.
Posted on Sep 09, 2009
SOURCE: HP business inkjet 1100
This very simple solution works on my Business Inkjet 1100.
1) Turn the printer off, then back on, to clear the error.
2) Set your computer's clock back to a date prior to the cartridge expiry date.
3) Print something, (any documents will do).
4) Set your computer's clock forward to the correct date and the printer should still print, and ignore the expired cartridges.
My 1100 re-checks the cartridges and dates occasionally, but not frequently (it has been about two months between checks) so you might need to repeat this process every two months or so until you have used up your expired cartridges.
This solution is much easier than dismantling the printer and changing/removing wires!
Posted on Dec 16, 2009
How do I set up to scan as PDF?
download CutePDF, a driver that work as a printer.When you want to print any doc, on the print properties you will choose CutePDF, and the printi doc will be as >PDF file.
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
My officejet printer says that there are 2 docs in queue but nothing has printed in over 1hr
First dont wait and hour for something to print.. 2nd reset the Printer or go into the cue and delete the pending documents
if its an office jet you need to unplug all wires including network cables or usb let unpluged for about 15 minutes then plug back it should clear the que
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Jan 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Need to reset my printer
Easiest way to reset a printer of this style is to unplug it for around 5 mins.
But be sure the computer doesn't have the document still in its printer cue, look on the bottom right of your windows screen and double click the printer icon and clear all the documents out
Jan 02, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
