Question about NEC Dterm DTP 16D-1 Corded Phone
How do you program extension numbers on a Dterm 80?
SOURCE: NEC DTerm 80
Try dialing the numbers 725 and then hang up...to turn it off..same thing. Ours works this way at work.
Posted on Apr 18, 2008
SOURCE: NEC Dterm 80
http://www.battscom.net/User%20Guides/IPK/IPK%20Multiline%20Telephone%20UG_2b.pdf
Posted on Oct 10, 2008
  • 13 Answers
SOURCE: NEC Dterm 80 LCD display is defective.
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
Posted on Dec 08, 2008
  • 149 Answers
SOURCE: I have a 4 line NEC Dterm 80 phone. How do I recall the past
depends on the type pf system. Do you have a coib installed in the system? Is caller id setup or programmed? If there is no mif card in the switch you cannot save caller id info. It only shows up when the phone rings and while on the call. There should be a directory key that you can price to scroll through the numbers if everything above is correct. ldtsnj.com
Posted on Jan 02, 2009
  • 149 Answers
SOURCE: I need to change my display name for my Dterm 80
you need to access program mode on the phones.
mb 4-18 is name assignment
new station is 4-10
ldtsnj.com
Posted on May 15, 2009
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
Hi I cannot get the headphone set to work with the NEC Dterm 80 phone. Headphone model is Compucessory 55251. Thanks very much.
you need to program a headset key on the phone in memory block 4-12 for that extension. You can assign a line key as a headset key to make the headset port on your phone usable. ldtsnj.com
Jul 07, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I need to change my display name for my Dterm 80 phone. I also need to add a name and extension
new station is 4-10
ldtsnj.com
May 11, 2009 | NEC Dterm DTP 16D-1 Corded Phone
PROGRAMING THE SPEED IN THE D TERM 80
feature, redial, button allocation # sys=0-79
sta=80-99
dial 1 for number
than 9 plus full phone number
feature to save
Apr 09, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How do I make a conference call with the NEC Dterm 80? Thank you.
To establish a 3 way conversation.
  • Pick up handset and dial first number required
  • While on the call, press Transfer (TRF) button
  • Caller will be placed on hold
  • Dial extension number or external number
  • When called answered by third party, press CNF to establish a 3 way conversation.
Note: Any party may exit conference by hanging up
Mar 05, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Have NEC D term 80 phone without manual
The manual is here.
NEC doesn't call it the "Dterm 80 manual," but that's it. It's titled "Electra Elite IPK II Multiline Telephone User Guide."
May 02, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTERM 80 Call to speakerphone
While the station is ringing - Press "1"
The feature must be enable in programming to be active.
Mar 06, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
73 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
