Question about Compaq Inkjet Ij300 Printer
Wont show up in my file
I am trying to print but the printer does not show up on my laptop. I do not have the cd so i can not program it in my laptop again. Is there anyway i can get it to show up?
  • boka251615 Aug 22, 2008
    i have the compaq IJ300 printer however i lost the disk to download the printer to my desk top computer
  • kristy ligh nelson
    kristy ligh nelson Sep 01, 2014
    you could get a new printer or cal 3544378943 and they will help you
To add printer software into my laptop.
Posted on Dec 03, 2008
    President:
  • Compaq Master
  • 2,022 Answers
Kaju, pls download the driver from this linkhttp://members.driverguide.com/driver/detail.php?driverid=77667&action=summary
Posted on Sep 26, 2007
SOURCE:
What is the solution if the printer didn't print?
  • When you try to print from a program like microsoft word, clicking print command it should bring up a print window and there it shows what printer the program will print to before you click print. If there is no printer installed it often shows printing to a file, (instead of printing on paper).
    Computers need to have a driver installed for that model of printer before it can print. That is done by downloading the install file of that printer for the operating system you are using. I see you seem to be using Evolis Primacy ID Card Printer. If the driver program is not installed, try going to the link below, I found that by searching key words in Google Search.
Primacy
Jul 07, 2016 | Evolis Primacy ID Card Printer
Where is the option of printer in toshiba t1350 laptop
You have to install the driver for the printer yourself. Go to the Toshiba website and download the driver for the printer (in case you have the cd software that came with the printer you can install the software from it).
After installation if you want to print something go to File/Print Setup of the browser or Word or Photoshop or whatever program you have your file in. Select your printer, type of paper and other items like print quality. Then Print.
Please rate Fixya answers.
Mar 07, 2011 | Joy Satellite M105 S3031 Laptop
It won't let me print anything because it is trying to print an old thing but it isn't working, so i tried to cancle it but it wont let me. what do i do?
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 11, 2010 | HP PSC 1350 All-In-One Thermal Printer
The printer is connected, but won't print and is showing error message and showing troubleshooting. i have checked all the leads and switched it off and on.
This is very useful tool for your future assistance too. This will resolve your issue.
Regards,
Ron
Nov 04, 2010 | HP Office Equipment & Supplies
When I go to send to print, it closes the
Try completely uninstalling the printer drivers and software,then go into the program files folder and make sure the folder for that is also gone,if not,delete it.Make sure your printer is unplugged from the computer before you do this.After you have completed the procedure,restart the computer and insert the printer install cd,install all the drivers and software again,then plug your printer back into the computer,it will say "found new hardware".When its finished,try printing again..hope that solves your problem:)
Apr 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
Scanner problems
This worked for me. You want to start fresh so delete your HP printer in "Printers and Faxes". Also delete any HP software that loaded in Control Panel "Add and Remove Programs". Next in Control Panel under "Add and Remove Programs", the "Add and Remove Windows Components" TAB, check mark the file to add called "Other Network File and Print Services". After clicking next, the extra print files will load. Reload your software/ HP drivers and it should be fine.
Jul 05, 2009 | HP Office Equipment & Supplies
"File ImageCach.ic could not be accessed"
The Canon Program "CD-Label Print" has issues with Windows 7.
I solved it this way:
  1. Find the "CDLabelPrint.exe" most likely under "C:\Program Files\CD-LabelPrint"
  2. Right-Click on the File and choose Properties
  3. Select "Compatibility" and tick "Run Program ... Windows XP (SP3)"
  4. Push "OK"
  5. You should be fine now
See Picture for Details.
May 11, 2009 | Canon PIXMA iP5200R InkJet Photo Printer
HP Officejet 6110 stops printing. Installation of updated software and drivers stops without any warning
Try a complete uninstall:
Unplug the USB cable from your PC.
Go to Control panel add or remove programs. and delete all the entries you see for HP.( If it promts a restart do not restart now)
Then open my computer> C:drive> Program files> and delete the HP Folder only (not Hewlett Packard)
Then Open C:drive> Program files> Common Files and then delete HP and Hewlett Packard folder.
Then Go to C:Drive> Windows> Temp and empty the temp folder as much as you can.
Then go to Recycle bin and empty recycle bin.
Then Insert the All-In-One CD and cancel the installation process.
Open the content of the CD> and open Util folder> Then CCC> Then click on Uninstall_L4 and follow the on screen process.
After all restart the computer.
And if possible download the latest printer driver from HP website and install the same
Let me Know if any problem
Good Luck
Sep 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
CAN NOT PRINT LWORKS FILES IN EPSON STYLUS C84 PRINTER
Hi there HarryW - what is the "LWorks" program? Is it a Windows program - if so, you don't need a separate driver for it. All you need to ensure is that the printer is properly installed on your Toshiba as a Windows printer. If it isn't installed, just insert your Epson C84 CD and follow the instructions.
If you don't have a CD, go to
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23953&prodoid=36033903&infoType=Downloads&platform=All
to download the driver (Printer Driver v5.4cA).
If Lworks is not a windows program, or if you have any further queries, report back to me with a new comment.
Please rate this solution if it has been helpful to you.
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
Why wont my printer pirnt?
hi im Jules_09,check you connection to your computer r your cannon has to be reset because of the driver you installed
Dec 20, 2006 | Canon CLC 1180 Copier
Compaq Inkjet Ij300 Printer Logo
63 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Ekse
Damen Wong
Damen Wong
Thomas F. Schneider
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
