Question about Garden
Have areas of brownweeds in my lawn.They seem to be taking over my lawn
Transmission went out was wondering how long does it take to take the old one out and put a new one in
for me 30 min. for you could be hours. depends on how many you've done. I've done plenty
May 31, 2015 | Toro 36" Cut Wide Area Walk Behind Lawn...
What causes ztr front wheel to squeek in motion?
i would take them off and clean off the old grease and apply fresh grease on all moving parts including the the wheel caster section
Jul 14, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
I recently purchased a Sears 22 self propelled with rear bag
they only catch grass not dirt they need air flow to work and if not porous they wouldn't work
May 31, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
I just inherited a Poulan Pro Electric 625 Series Self-Propelled Lawn Mower. I used it once...it started quickly but the self-propelled function doesn't seem to work very well. I have had other...
This sounds like a simple belt adjustment. Look in the area where the belt is . Look to see if there is an adjusting screw, or a movable pulley, or just something that will tighten the belt. Lift the mower and look underneath the mower deck. This may be where the adjustment may be. If you can't find the area of adjustment, then you may have to bring in to the repair guy. Either way it's cheaper than a new mower. GOOD LUCK>
Jun 28, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Snapper LT 200 20HP is only a year old and only keeps a battery charge for 3-4 days. We changed the battery and still have the issue. I have confirmed that the key has not been left on. It appears that...
The charging system could do this Take the hot wire off the starter and set for a while and see if battery runs down. Then you know what area to look. If there is a separate wire on your charging system take it off and see if that looses power. Try trial and error Its cheaper that way.
May 06, 2011 | Snapper 20 HP Lawn Tractor 2690578
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
Left the electric lawn mower in the rain this winter thinking it was like the gas one. Will not hold a charge. How do we fix?
If you are not mechanically inclined, You may want to seek the help of your local mower shop. However, If you can take the top off. Make sure you make a diagram of the wiring or a picture before you take any thing apart. Take the batteries out and get them load tested. If you have a Battery Plus in your area, You may be able to get new batteries from them.
Apr 17, 2010 | Electric Lawn Mower
There does not seem to be a spark. I even put fuel
is the deadmans handle pulling the cable enough to cancel the off switch? if not relase the cable from the handle, TIE A KNOT IN IT(!), re fit to handle, & bingo!
If the cable is working well enough already DONT tie a knot, it wont help, its the ignition coil! ( around £30)
Apr 02, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Tiller usage
Power tillers are used for breaking up the soil. They improve conditions for new plantings, develop gardens, weed, and reseed lawn patches. A power tiller takes the toil out of large or difficult projects. Below you will see the three main types of power tillers available. Choosing between them generally depends on the size of the area you wish to till and the type of soil in your area
Aug 27, 2008 | Mantis Lawn Dethatcher Attachment
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
