Question about Dryers
What is the cu ft. size of the GE Dryer Model 453? I have the receipt and manual from April 2000 and no-where does it indicate the cu ft. size. I would greatly appreciate your response. I believe the tub bushing was shot, didn't want to replace so, bot a new dryer with a 7.3 cu ft. capacity. I'm just curious as to the size of my old GE dryer 453 model. Hated to depart with it, the 453 was a great product.
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Posted on Sep 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer capacity
Yes, a full size dryer as yours is easily capable of drying a full sized load from the washer you mentioned. The wash tubs in the new model washers and dryers still maintain a standard size. For example, the front loader dryer that I purchased to match my front loader washer is completely identical to earlier standard models without all the fancy packaging. I could have saved some money and purchased only the washer, but...the wife needed a matching pair.
Now, you will still have to properly sort items to ensure they dry efficiently. A copy of your dryer owner's manual will describe this to you. I'm not here to give you lessons in how to dry your clothes, but if you do not own a copy of your manual and would like to refer to it, you can obtain a copy at geappliances.com. Just look under the "Service and Support" section for "Use and Care Manuals". Just type in your model number and your owner's manual is availble in a downloadable .pdf format.
The point I'm attempting to make here is that although you can place a full load from your washer in the dryer, if you do not properly separate certain items, they will not dry properly. I did not want you to think this was a cause of the appliance.
In addition, make sure the dryer vent ducting is properly cleaned and not clogged anywhere. This can also contribute to longer dry times.
I know you were only asking a simple question. I just wanted to be thorough in case additional question may arise. I hope this information is helpful to you.
Posted on Nov 14, 2008
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
aquaman987
  • 927 Answers
SOURCE: I need to buy a
It appears to be 5.8 cubic foot capacity. Confirm this with the store when you purchase your next dryer.
Gary
Posted on Sep 03, 2011
  • 29 Answers
SOURCE: how to check and replace dryer's heating
unplug the machine from the wall - open the door and look in the top of the door hole - there will be 2 screws there - take them out and you will be able to lift the top off - the heating element is located behind the drum on the rear wll of the cabinet - use an Ohmmeter to test the element for continuity - if it is open - you will need to remove the front of the dryer and then the drum to replace the element - if it is continuituos the problem may be a fuse or thermostat or broken wire or an open timer
Posted on Oct 01, 2011
How many cubic feet are in GE electric dryer model DHDSR46EE1WW?
Features
  • 7.0 cu. ft. super capacity
    Handles large-size items and family-size loads
  • Auto Dry
    Uses thermostats to monitor air temperature and reduce fabric wear
  • Dura Drum interior
    Provides long-lasting dependability
  • Four heat selections
    Provide the right temperature for the right drying results
  • Interior dryer light
    Lets you see everything inside for easy loading and unloading
Sep 13, 2015 | GE Dryers
Have GE harmony profile dryer about six years old. Interior light goes on but no other indication of power. Have checked cord, fuses and vent. Any suggestions appreciated. Hal Dresner
These dryer have a re-settable thermal limit mounted on the heater. With any luck that is all you need to do is clean up the fluff in the dryer and reset the limit. Here is the service manual
Nov 29, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Size of Model No. TAX4SNYBWH\r\nSerial NO. SS143822 Manufactured 9/97 GE
Owner's Manuals and Installation Instructions The following documents were found for model number TAX4SNYBWH.
In some cases, installation instructions may be found in the owner's manual.
Requires Adobe® Reader®
TAX4SNCWH
GE® 4.3 Cu. Ft. Spacemaker® Compact Refrigerator
Aug 12, 2010 | GE Refrigerators
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE Harmony gas dryer wont heat
post your email i will send you the servuice manual on it
May 08, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
DPGT750EC1WW
anyway...
GE Profile Harmony™ 7.3 Cu. Ft. Capacity King-size Electric Dryer with Stainless Steel Drum
Use and Care Manual
Quick Specs
hopes that helps...
Jan 26, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
