Question about Kitchen Ranges
I need the manual to the jenn air model S105 to show how to replace the oven door latch for self cleaning
4 Suggested Answers
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Jenn-Air free standing range: displays
Hello there
This a common problem with these
F9 Door lock safety circuit on power relay board sensed Replace power relay boardok I would contsact the nearest appliance parts repair center to see if this can be replaced and how much it would cost and mayby you can do it yourself it would save you a lot of money ok?
hope this is very helpful for you
Best regards Michael
Posted on Jan 18, 2010
My oven shows a f9-3 code how can i fix this short of calling a repair person
The F9-3 error code means that their is a problem self clean door lock system. Typically their is 2 switches that check the position of the door latch and even if it's open and not in self clean mode the switches are telling the computer the latch is closed. You should if fairly mechanically inclined be albe to find the latch behind the control panel and use the wiring diagram there and check those switches using a meter set to a low ohms setting and check for one switch being open (infinate ohms resistiance) and the other to be closed (zero ohms)
Good luck, i hope this helps
Gene
Jul 31, 2011 | Jenn-Air JJW8530C Expressions Collection...
Self cleaning oven doesn't work and makes loud noise when you close latch
Hi.
The door latch mechanism must be replaced after reading impedance and volts from EOC to latch.
This kind of problems can be caused by the high temperatures generated on self cleaning cycle.
Regards.
Mar 01, 2010 | Jenn-Air Kitchen Ranges
How to turn off self clean oven Jenn air slide in older model after it is done cleaning
the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
Oct 08, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
Jul 18, 2008 | Jenn-Air JJW8430D Electric Double Oven
OVEN NOT WORKING
You have probably damaged the latch and other sensors around the door. Make sure that the is not bent or out of alignment.
more asst.
eboukater@gmail.com
Jul 01, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
