Question about Garden
I need a replacement chain for a Parkside chainsaw
  • 4 Answers
I think any chain of the same size will fit if not contact company for replacement parts
Posted on Oct 16, 2013
3 Suggested Answers
  • 61 Answers
SOURCE: homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
Posted on Jul 10, 2009
  • 4088 Answers
SOURCE: ryobi cs214 chainsaw what chain is needed for it?
Take the old chain to a servicing saw dealer that can cut and make up one to fit nearly any saw made. Plus, they will usually give you good tips on maintaining the new chain as well. Hope this helps!
Posted on Jun 21, 2010
Troubleshooting chainsaw
You need to clean the chainsaw areas where the dirt has gone with a water hose. You may have clogged up the oil thing that puts oil on the chain. Hope this helps! And yes, dirt will make a chain dull. You might have to replace the chain or have it sharpened.
Jul 20, 2014 | Echo Cs-310, 14" Replacement Chainsaw...
Parkside chainsaw eks 1650
Hi Zbig,
I have searched extensively for this manual but cannot find a copy.
I have e-mailed the distributor in Germany to see if they can provide instructions. If they don't get back to me within a reasonable amount of time, I will let you know and you can cancel the $12 fee. There should be a button you can click to do this.
Sorry I can't be of more help at the moment!
Jan 29, 2012 | Tools & Hardware - Others
How to change a chain
First of all, make sure the saw is off. Also, before removing bolts, make sure the chain brake is not engaged (the chain should move freely).
Remove the guide bar side panel. Using a scwrench or wrench, unscrew the nuts and remove the plate to access the chain.
The side plate on most chainsaws will be held on by two nuts. Loosen the blade adjustment screw (a pin that is usually driven by a screw and pushes the blade out from the chainsaw to keep the chain tension tight).
The old chain is ready to be removed now that the sprocket plate is off of the saw. Pull the nose of the chainsaw's bar away from the chainsaw to release it from the tensioner.
Remove the old chainsaw chain.
The chain will easily remove from the guide bar with all that slack in it. Note the orientation of the cutting edges of the chain so you put the new one on the same way.
Pull the drive links out of the guide bar and slip the other end of the chain around the clutch drum.
Steps to Install a New Chainsaw Chain
Thread the new chain onto the saw.
Carefully thread your new or recently sharpened chainsaw chain around the chainsaw's clutch drum, making sure that the drive links engage in the sprocket.
Thread the rest of the drive links into the guide bar and around its nose, making sure all links are in the guide bar slot.
Align the guide bar.
With the chain properly threaded along the clutch drum and guide bar, put some tension into it by pulling on the nose of the guide bar away from the chainsaw.
While pulling the guide bar, make sure to seat it onto the saw's adjustment pin.
Replace the side plate.
The side plate is ready to go back on as long as the guide bar is properly positioned beneath.
Replace the plate and the nuts that hold it into position, but do not tighten the nuts down all the way yet. The guide bar must be allowed to move a little while the chain is tightened to the correct tension.
Tighten the chain to the correct tension. Use the tensioning screw to the side of the guide bar to adjust the tension on the chainsaw chain.
Finish tightening the side plate nuts.
The chainsaw chain replacement is now complete.
And here is a great overall reference guide to keeping a chainsaw sharp and running. Sharpening a chainsaw chain is a great way to extend the life and is less expensive and easier than replacing a chain. There are small grinding tools (like a dremel) that can be run off a small 12v battery or your vehicle battery that allow for quick 'tune-ups' on your chain if you are out cutting and need to sharpen your chain.
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Aug 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Ryobi cs214 chainsaw what chain is needed for it?
Jun 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a MAC 3516 and need a replacement bar and chain. The original Chain and bar are not available. the saw runs good but need the primer bulb and chain bar and chain. Any ideas would be great.
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | McCulloch Garden
Need to replace chain on 450s mcculloch chain saw
You might want to purchase a combination set with a new bar and chain, if so, Oregon #108764 is the 16" length set.
If you only want either a chain or bar, then the following are the correct ones for your chainsaw:
Chain 16" @ 3/8" pitch = #91VX054G (low profile, semi-chisel)
Bar 16" = Oregon #160SDEA318 (w adjustable chain tensioner)
Bar 16" = Oregon #160SDET318 (no adjustable bar slot for use on chainsaw originally equipped with the Intenz bar only)
Hope you find this very helpful and best regards!
Aug 16, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How to replace chainsaw on blade too much slach in chain
Are you sure you need to replace the saw chain? There should be a screw adjuster near where the bar attaches to the saw which tightens or loosens the chain on the bar... You will have to undo the nuts holding the bar onto the saw body slightly first so thew bar can move forward and backward when adjusted with the tension screw to apply tension to the chain to reduce the slack.
Jun 14, 2009 | Remington Polesaw Wizard
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
