Question about Yard Man Garden
Yardman riding mower no reverse forward jerking motion
    Sergeant:
  • 224 Answers
It sounds like you either have a lose belt that is slipping or the fluid in the transaxle is low, or the transaxle is going bad, if it is a hydrostatic transaxle, drain and replace the fluid first, if that fails, you may have a bad seal in the pump or a worn gear
Posted on Oct 17, 2013
4 Suggested Answers
  • 205 Answers
SOURCE: Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Posted on Mar 21, 2009
  • 11 Answers
SOURCE: Honda HTR3009 riding mower runs great but won't
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Posted on Jun 24, 2009
SOURCE: My MTD Yardman ride on mower seems to be stuck in gear, in that it wont move. Is there some way I can release it?
thanks man I think I just found my problem
Posted on Oct 07, 2012
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
unset the brake push pedal all the way down and release it
Apr 10, 2015 | Garden
Lawn mower transmission
This can be a loose belt that is slipping, low fluid in the transaxle, a bad pump (if hydrostatic transaxle) or worn gears, start by checking belt tension, then replace the fluid and filling to proper level, if that fails, the trans will need to be inspected for internal damage to pump and gears
Oct 16, 2013 | Yard Man Garden
After I apply the brake going downhill, etc., the mower jerks severely and repetitively in forward gear like the transaxle is slipping and catching. Any ideas why?
I believe when you push in the brake you remove tension from the drive belt and engine. Their is a spring that pushes back on the brake pulley and your peddle. check this for wear
Feb 23, 2011 | Yard Man Yardman Riding Lawn Mower 38in...
I cannot get any speed from my MTD/Yardman riding lawnmower. I have change the belts. It will engage But just will NOT go very fast. It is a sem-automatic.
Your yardman mower is a hydrostatic model which uses a small hydraulic pump to turn a hydraulic drive motor.Check there is sufficient oil in the transmission. Check the forward/reverse lever travel, and adjust as needed to increase the "throw" to move the swashplate in the hydraulic motor.
Jan 04, 2010 | Garden
Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Oct 19, 2009 | Garden
Could anyone help me with manuals for mtd yardman dx70 ride on mo
My HE4160 goes like hare in reverse and like a turtle forward.
Any drawings showing how the springs are fittted behind the left back wheel.
tks
Apr 04, 2009 | Mtd Garden
Garden Logo
124 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
