Question about Elkay EZS8 ADA Barrier Free 8 GPH Water Cooler Refrigerated Drinking Fountain
I have a old Elkay water bottle cooler. Model EBAC-1-1 ; Serial # 890616311. It stopped flowing smoothly and I believe I need a new spigot. I screwed it off soaked it in vinager, but no help. I need to know what size of spigot for this model. I can't find that information on line.
5 Suggested Answers
muralme
  • 20 Answers
SOURCE: elkay water cooler does not turn on
You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
Posted on Jul 17, 2009
  • 127 Answers
SOURCE: water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Posted on Oct 18, 2009
  • 169 Answers
SOURCE: water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Posted on Dec 10, 2012
    claudeinmo
    • 9098 Answers
    SOURCE: elkay kitchen faucet model lk7124 replace stem
    ELKAY ' Strainers, Fittings + Other Accessories for the Home
    www.elkay.com/strainers-fittings-other
    Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
    ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
    www.elkay.com/
    Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
    [PDF]SPECIFICATIONS
    aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
    LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-ArcĀ® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
    Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
    www.amazon.com > ... > Faucet Parts
    Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
    Elkay A51947R Replacement Diacore Cartridge with Brown ...
    www.amazon.com/Elkay...Replacement.../B0033UX8...
    Amazon.com, Inc
    Posted on Jan 14, 2016
    I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
    The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
    Mar 08, 2013 | Cars & Trucks
    How to adjust water flow coming out of bubbler
    Check stream height from bubbler. Stream height is factory set at 35 PSI . If supply pressure varies greatly from this, remove the (bottom cover plate) and adjust the screw on the regulator Clockwise adjustment will raise stream height and counter-clockwise will lower stream height. For best adjustment stream height should hit basin approximately 6-1/2" (165mm) from the bubbler.
    Mar 02, 2011 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
    I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
    Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
    On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
    Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Have made the manual adjustments to increase the water flow but no increase in flow out of the bubbler. Is there a filter or part that needs to be replaced to allow better water flow?
    Have made manual adjustment to increase the water flow with not much change at the bubbler. Is there additional work that I can do to increase the the flow? I have siffient flow for supply but what comes out of the bubbler is barely drinkable. Possible a filter or other parts may need to be replaced?
    Oct 18, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Water pressure is low on the elkay fountain
    Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
    Elkay water cooler does not turn on
    May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Igloo free standing water cooler/heater MWC 500
    My spigot on my hot side broke off my cooler # MWC500
    how can i order this part
    Mar 23, 2008 | Refrigerators
    Elkay EZS8 ADA Barrier Free 8 GPH Water Cooler Refrigerated Drinking Fountain Logo
    48 people viewed this question
    Top Elkay Baby Gear Experts
    Dorel UK
    Dorel UK
    Are you an Elkay Baby Gear Expert? Answer questions, earn points and help others
