Question about Sony KDS-R50XBR1 50" HDTV
TV turns off anf on
My Sony tv is randomly shutting off and coming back on. It can go for several hours or it could be every two or three minutes. Sony really had no solution other than leaving it unplugged for a little or making sure it was plugged directly into an outlet. The lamp indicator trouble light on the front of the tv is not lit and the tv doesn't blink in red for the trouble codes when it shuts off. Any ideas?
  • 8 more comments
  • parkerdream Nov 09, 2007
    I have the same model with the same problem. I have had the unit about 20 months. Used to have DirecTV, no issue. Switched to Verizon FioZ about 5 months ago and the problems started. Like somebody suggested I unplugged the HDMI, power cables and I have the same problem. It has gotten worse, shuts down about every couple minutes. HELP>>>>>>>
  • Anonymous Nov 16, 2007
    TV turns off and on. Problem has gotten worse in the last couple of days. TV was purchased in May of 06. This is the second major problem with this TV. The color-block has been replaced.
  • rclipc Nov 20, 2007
    I'm having the same problem. Originally it was every now and then. Had Best Buy out to fix it during warranty but they couldn't find a problem and they were unable to do anything if it didn't do it while they were there. Problem seemed to go away for a while. Now it's back and it does it every 15 minutes or so. Shut off, green light blinks a while and comes back on. I talked to Sony and they blew me off even though it was a pre-existing condition while it was under warranty. It's almost beyond usable. We're now considering calling our Attorney General and the BBB. This is ridiculous...$3000 for a tv that lasts a year and a half. We also have had the light engine replaced because colors were bleeding. I've tried unplugging the tv for a while but no help.
  • oak139jv Nov 27, 2007
    My same model TV has the same on/off problem. It was purchased on May 06, now is just unusable because it switch on/off every 2-3 minutes. Please let me know if you had same problem and found a fix. Thanks a ton.
  • jaxrad Jan 04, 2008
    I have the 60xbr1. Same issue. Bought in Jan 06. Sony was less then helpful. Checked the lamp, fans, put it on high altitude mode ( just in case was getting to hot) unplugged plugged directly to a wall outlet nothing is a 3,750 dollars piece of junk in less than 2 years. We should join forces and sue Sony again for this issue.
  • jotache Jan 13, 2008
    I have the same problem. It stays on for 2-3 minutes and then goes off for 20-30 seconds...... This is unacceptable. Any one out there with a fix?
    I've gonne over the Operating Instructions looking for a solution but there is nothing there. Sony should admit to the problem and order a recall.
  • Frednecker Feb 17, 2008
    I also have the same problem...on off...I have the repair guy coming out and will let all know what they say.
  • Anonymous Apr 21, 2008
    Mine did the same thing. I replaced the lamp and it works fine now. There was alot on dust on the vents for the lamp. The lamp was 3 1/2 years old so I did not mind replacing it,
  • Anonymous Apr 25, 2008
    I'm having the same problem just started today Sony told me the exact same thing as you unplug it. Just got the thing fixed 6 months ago from recall they had. Has anybody found a solution yet I'm assuming the tech. I call will be out next week and charge me hundreds of $ to get it to work for another 6 months.
  • scity Aug 15, 2008
    I'm having the same issue with my XBR50 the tv will shut off but the green power light stays lit. It will come back on after a few seconds or up to a few minutes.I had a repair man out and he said it was impossible. I argued for a while and he finally called Sony tech support and they agreed with him, but they told him to "replace the guts" because it could be losing communication between the two.The repair man said it is a very expensive repair because it contains 80% of the television's electronic parts. Thank goodness I have extended warranty.
    Habit-Forming:
    New Friend:
  • 5 Answers
I have the same problem with a KDS-R50XBR1. The video and audio goes off, the power/standby indicator blinks green 52 times and then the picture and sound comes back, until it does it again. I haven't found any definitive technical info to help troubleshoot. Sony Customer Service was no help.
I replaced the lamp and the problem went away for several weeks, then it started back but only infrequently. It has increased somewhat in frequency over a few months. It acts like it might be related to a component in the lamp power circuit overheating and tripping a limit switch until it cools down and comes back on. I don't know if there is such a limit in the circuit, this is only based on the symptoms I observed. The older the lamp the more frequently it seems to happen.
Several times I've even had the video/audio go out and the red lamp indicator blink. After trying several different things (unplugging the TV, removing/replacing the lamp housing, cleaning the cooling fan, etc.), I've been able to get it to come back, but the cause was not clear to me. Once, when this happened, I tried putting the old lamp back in and it came back on but it triped off/on more frequently, just like it did with this lamp before I had replaced it. I then put the replacement lamp back in and it worked, it went back to the much longer trip cycle. I'm suspecting the lamp ballast/power supply block is causing the problem but I havent tried replacing it yet to confirm my suspicion. That is the next thing to try.
I don't trust that having a local service call would be successful without the tech replacing all of the parts that could possibility cause the problem. That would cost more than the TV is worth.
There have been an exceptional number of costly problems associated with this TV and, while the picture is very good and I like the TV when it is working properly, there comes a time when it doesn't make sense to continue throwing good money after bad. Sony customer service has been very poor too and, after my experience with this product, I'm rethinking my opinion about all Sony products.
Posted on Nov 29, 2009
  • 4 Answers
I finally got this problem fixed. I posted on another forum and found that when a bulb starts to go bad it can cause these TVs to do strange things. You can replace the bulb for less than half the cost of replacing the whole housing. See how here: www.geocities.com/bob_lipp
Posted on Feb 18, 2008
    Genius:
  • 1,694 Answers
Unplug-replug any/all connectors one at a time, including PCB edge connectors.
Posted on Sep 26, 2007
SOURCE:
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My Sony TV, model no: KDF-46E2000, all of the sudden started shutting off randomly every couple minutes. It then takes between 30 and 60 seconds for it to reboot, or turn back on. This happens whether...
It is problem of weak lamp that has been reached to end of its working hours life, replace lamp in tv to fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Thanks.
Nov 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony 36xbr800 shuts off on own
sounds like one of your color tubes or a system board is failing and will have to be tested and replaced by repairman
Feb 11, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony kv27v22 TV
check horizontal drive tramformer for intermitance is common problem some time blows horiz transistor to or vertical IC intermintence to
Apr 01, 2008 | Sony KV-27V22 TV
Power shutting off and coming back on
The problem is your bulb is going out or malfunctioning. I had this same problem and Sony's repair service couldn't fix it. I posted on another forum and found a great tv repairman that told me that when the lamp is going out or bad that it can cause the tv to do strange things. I replaced the bulb and the problem is gone. Here's a tip, you can replace just the bulb for about half the price of the full lamp assembly. Sony wants $250 but I bought just the bulb for $125 on ebay, spent 20 minutes taking apart the housing to replace the bulb. Just make sure you take note of how the spring is installed before you take the first part off. Other than that, piece of cake.
Apr 15, 2007 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 shutting off
When the lamp becomes weak in this Sony the unit will shut off intermittently. I would replace the lamp and use only an OEM Sony lamp, not an LTI or other knock off. The knock off lamps are of poor quality in my experience and opinion.
Apr 15, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDS-R50XBR1 50" HDTV Logo
178 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
