Question about Bamix Gastro 200 Handheld Blender
My husband washed my bamix and now the blade and rod fall out, I think a screw has come off, couldn't find anything, he didn't notice at time. Can I fix it are there any parts you can buy, it's about 4 years old and great condition. Cheers susan
4 Suggested Answers
SOURCE: 25-30 year old Bamix M100 - 240V 100W
Those small plastig bungs do come out, you will need a fine probe to prise them out then you will see 2 philips head screws which hold it all together, not sure how you will tighten your shaft though, looks like it might be moulded into the plastic retainer, good luck! on mine the motor bearings are seized,
regards,
Dave Pary.
Posted on Mar 18, 2009
  • 6 Answers
SOURCE: I inhertited a bamix recently,
eBay and amazon
Posted on Apr 24, 2011
  • 10 Answers
SOURCE: old bamix - motor on
If possible, check the spot where the blade fits onto the driveshaft. It's probably a toothed gear or wheel. I have had blenders "die" before due to wear between the drive shaft and the blade. The blade would bump along inconsistently as the gear teeth failed to catch.
Posted on May 04, 2011
I need attachments
It seems you can no longer buy the HA-3058 or parts for that, however Bamix sells a similar product it seems to be the same machine with only a few aesthetic changes.
They sell many accessories and you can get blades.
Check:
http://www.bamix.com/
http://www.bamix-blender.co.uk/
I have had our customers buy the Bamix blades for the MegaMix HA3058 and the blades are interchangeable on those machines.
-Colleen@ MendingShed http://www.bamix.com/ http://www.bamix-blender.co.uk/
Apr 06, 2015 | Blenders
How can I Loosen the spring blades on a Bamix mixer attachment
You are lucky. they usually fall off mine.
However you can gently ease them off with small needle nosed pliers.
May 23, 2014 | Bamix Blenders
Rusting blade
Why don't you just clean it?
Very carefully use a soap pad, and then dry thoroughly. remember to dry thoroughly after every use, and wipe a little veggie oil on the blades with a paper towel.
Apr 07, 2014 | Bamix Mono Handheld Blender
How do i change the blades to change function
Website for company: http://www.bamix-usa.com/
Search by model on the site; they have streaming videos that may answer the issue.
May 17, 2011 | Bamix Deluxe Handheld Blender
Old bamix - motor on but the blade does not turn. unscrewed the bottom casing and cleaned out the oily part but still not working?
May 03, 2011 | Bamix Mono Handheld Blender
I am unable to remove the blade, what can I do
the blade is a screw fit on the shaft of the blender,, if you only use one blade just rince the blade under the tap and dry it off before putting it away, the only way to un-screw the blade if its stuck is give it a sudden jolt on the side of the blade with a soft hammer in the same way as it turns,,this may shake it lose,,,not to hard though,,,
Nov 15, 2009 | Bamix Mono Hand Blender - Black...
I have a Bamix Immersion Blender, but it stopped working. Press it on and it makes a humming sound but does not move. Where (in Canada) can it be repaired or replaced?
Sounds like the motor shaft has broken from the impeller. If I had it I would crack the case and see if that were true.(You might see screws holding the case together- If not, they might be hidden under the cosmetic label. If it is true, you need factory help. You better call Customer Service for Bamix.
THis is from http://www.bamix-usa.com/:
The drive shaft is frozen i.e. no longer rotates although the motor still hums: place the operative part of the appliance for 5 to 10 minutes in a jug of hot water, then switch it on. In general the appliance will then work again - if not just try to free the shaft very carefully with pliers
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers Processor/Dry Grinder: Discoloration of the bowl (i.e. carrots) can be cleaned with a cloth impregnated with salad oil.
Oct 23, 2009 | Bamix Immersion Handheld Blender
Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
Mar 17, 2009 | Bamix Mono Single-Speed Handheld Blender
Instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise 1 egg (or 1 egg yolk) 1 teaspoon of lemon juice 1 teaspoon of herb vinegar 1 pinch salt 1 pinch pepper 1 ½ - 2 cups of oil 1 teaspoon of french mustard Put all the ingredients except the oil in a jug (not too large) and blend well with the WHISK. Then add the oil in a thin, steady stream (not drop by drop), processing all the time, until the mayonnaise has reached the required consistency. To achieve perfect results, all ingredients should be at the same temperature.
go back
Dec 13, 2008 | Bamix Deluxe Handheld Blender
Bamix Gastro 200 Handheld Blender Logo
Top Bamix Blenders Experts
Ruth summersides
L Pfaff
L Pfaff
Stan Ford
Are you a Bamix Blender Expert? Answer questions, earn points and help others
