Question about Elicent Ventilation Elicent Inline Vent Fan 10" 695 CFM | 736767
Keeps making noise
Hi, i have an Elicent Venta in my bathroom. when i turn on the light it goes on automatically. The problem is - when i turn off the light, the Venta keeps working for another 6-7 minutes, making an annoying noise.. is there a way to make it stop once the light turns off?? PLEASE HELP :)
How can I make my own venta Airwasher Water Treatment?
I use white vinegar and hot water. I soak the disk for a few hours. It's amazing. My venta is 10 years old. I also use different scented oils in mine to fragrance the room. I use it daily. I got a new venta but like the older model better. It is my sleeping machine it provides a white noise that I sleep very well to. The new one is too quiet and seems more fragile.
Mar 02, 2015 | Venta - Airwasher LW44 Air Purifier
Nautilus N678-C bathroom ceiling light/fan. Fan makes screeching noise. Will I need to replace the motor?
Possibly try spraying some wd40 where the shaft goes into the motor if that don't fix it get a new one
Oct 12, 2011 | Dryers
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
Hi, i have a 2000 blazer and my turn signal keeps on making the noise after the lights have stopped flashing, everything works properly except for this annoying audible noise,
the turn signal switch box is going bad.... i have a 2000 chevy tahoe limited edition and it is doing the same thing.... i'm going to change mine when it goes out... hope this helps....
Mar 31, 2010 | 2001 Chevrolet Blazer
How can I open an encased bathroom light?
I wish you had a brand and make it would make it easier since i'm not there. I hope this helps here it goes. Try pushing on the sides. Some encased plastic lights just clip in and pushing on sides relieves the pressure allowing the plastic encasement free. I know this is not much. Good Luck Jeff
Mar 23, 2010 | Home
Venta 205 no mist
Throw the unit out - it's garbage
Nov 10, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Venta Airwasher Display Light Blinking...
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Jan 30, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Drum does not turn
The rubber coupling is slipping. You may have a problem with the gear case; you can get a new one by calling Venta at (888) 333 8218. But it's possible that the rubber coupling is simply not seated properly. Snap the gear box out and make sure the socket is clean. When you put it back make sure that the coupling post is fully inserted in the drive socket. Hope this works for you ... Venta will supply new parts promptly if you decide you need them.
Mar 17, 2008 | Venta - Airwasher LW14 Humidifier
Venta LW44 - KNocking sound and only 1 of the 2 wheels turn
This sound is could mean that the life of the gear has been used up.
This is a common problem. It is easily fixed for $10 + Shipping. The gear needs to be replaced. Try this link to have someone call you. abdistrsupport@gmail.com
Remove the gear and turn on the unit to see if the noise still exists.
  • If noise stops, the gear and coupling needs to be replaced
Dec 10, 2007 | Humidifiers
Elicent Ventilation Elicent Inline Vent Fan 10" 695 CFM | 736767 Logo
236 people viewed this question
Top Elicent Ventilation Photography Experts
Tony
Are you an Elicent Ventilation Photography Expert? Answer questions, earn points and help others
