LG WIRELESS SPEAKER RECEIVER MODEL: W3-4 - Audio Players & Recorders
I have the philips mcm530 micro system and want to tune in a wireless speaker to the system so I can take the speaker outside. Is that possible?
The philips only receives bt audio it doesn't transmit them. You need a wireless system that includes a receiver and transmitter. The transmitter needs to be able to be connected to the speaker outputs of your philips system. Since I don't know what country you live in it is difficult to recommend anything as what is available in one area may not be available in another
Sep 01, 2016 | Philips Audio Players & Recorders
Can you use Lg wireless speakers SH93WA without the receiver that goes with it
If they have a place on the speaker to wire or plug, then definitely yes, if not frequency programming might be a problem.
Feb 03, 2016 | LG Audio Players & Recorders
Connect LG NB3520A to Fisher RS-625 receiver
You would have to install a speaker selection switch. You cannot directly hook up 2 amplifiers to one set of speakers without destroying one or both amplifiers. Unfortunately, one set of amplifiers is inside your sound bar. An external switch would have to be installed on your sound bar as well as speaker terminals that would connect to your Fisher.
If you have a line out or tape out on your Fisher, and you have an analog input on your sound bar, use could use that as an alternate solution. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | LG NB3520A 300W Sound Bar with Wireless...
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
My two wireless speakers are not working. the wireless receiver flashes blue 10 times then turns red. It was working fine and now is not
I am having the same problem with my LGHB905TAW. Called local support without any feedback... I think this is the bug in design phase.. Search around the internet but without any positive result...
Sep 27, 2011 | LG LHB975 Theater System
I just purchased a LG LE5500 55" TV. When using my accoustic research wireless speakers it creates an echo effect. The Geek Squad said there was nothing I could do to prevent this echo. Is there a way of...
try different ways of sending the audio to the speakers. you can go digital out from the tv into your receiver or go directly from your cable/satellite box into your receiver. I use both...from the tv for netcast and from the box for all others. assuming you are going through a receiver
May 08, 2010 | Acoustic Research 900MHz Wireless Stereo...
Power cuts off after 2 seconds after stereo start button is pressed
Disconnect your speaker wire's from your receiver, and then turn the receiver on.
If your receiver cuts off with the speakers disconnected, there is something wrong with your receiver, and take your Sherwood receiver to a qualified reputable technician.
If your receiver stays on with the speakers disconnected, their is a short circuit either in your speakers wires, or in your speakers. Make sure your speaker wires are pushed all the way in the speaker terminals in the back of the receiver, and do not leave no naked speaker wires exposed. If you have too long of bare speaker wires exposed at the receiver's speaker terminal, or at the speaker's terminals, they could touch each other, and cause the receiver to cut off. If the speaker wires are OK, then you may have a short circuit in your speakers.
Nov 12, 2009 | Sherwood RX-4105 Receiver
Hook up wireless speakers
I'm assuming the wireless speakers you have utilize an RCA jack to connect to the receiver.
Solution:
The good news is yes, you can use them on your receiver. The bad news is that the only output on your receiver is "VIDEO OUT" so whatever you want to watch or hear on the wireless speakers must be connected to the "VIDEO INPUT".
If the wireless speaker module uses speaker wire to connect to a receiver you will simply tap into the surround thumb clip speaker jacks.
I will add that wireless speakers tend to be disappointing when used in home theater.
Mar 24, 2009 | Sony STR-DE475 Receiver
LG wireless dvd reciever system
Hi, I had the same problem, it seems to be a design error of LG or a typical problem with some component in the wireless transmitter. It is basically caused by the transmitter heating up, leading to a clock drift with the result of the receiver losing the signal. I tried to cool the transmitter in the fridge before using so it will run for about half an hour before producing this error (depends on the room temperature as well). My solution is to remove the plastic case of the transmitter unit and place it in a cool place where it does not catch heat from other devices. Without the case it does not overheat and also takes less space, just be careful if you have children. I placed the naked Tx unit behind the TV so it does not matter. Hope this works for you as well.
Mar 21, 2008 | LG Electronics HTW316 5.1 Channel Wireless...
271 people viewed this question
 Grubhead
Grubhead
