Question about Smeg Ovens
Fan not working on smeg oven - Smeg Ovens
hongster
  • 6 Answers
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
vest6
  • 196 Answers
SOURCE: smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Posted on Jan 26, 2008
  • 1462 Answers
SOURCE: SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Posted on Oct 18, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
Smeg oven fan and heat not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 28, 2013 | Smeg Ovens
Smeg oven stopped working
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 27, 2012 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Does not heat up fan turns on smeg scp 111 multifuncation ELECTRIC oven
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Sep 10, 2009 | Smeg Ovens
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg oven
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Smeg oven
Jan 24, 2008 | Ovens
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
20 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
