Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
Kenmore 5.1 cu.ft. chest freezer with manual defrost (model # 255.19502) is not meeting my expectations. It was replaced by Sears after its previous model, 19502/19702 crashed while still under warranty. This model appears to be even more poorly made than the previous model. After my husband died and I had fewer family events to prepare, I downsized to a small chest freezer. They are hard to find! Consumers must not be using them much? Today I defrosted this model for the first time. The hard part was not finding the plug, but the hole where water drains out the exterior. It was taking forever, and I had a small test tube brush to clean out any debris caught in the hole. It was not clear to me where the drainage hole is supposed to be? Since I never received a manual of instructions, even online, I finally turned the whole unit over so I could inspect underneath. I won't describe my opinion of the way it is put together. I finally turned it right side up and used a few towels to absorb the rest of the water. Trying to drain the water into a shallow pan only produced a few tablespoons and it was not clear to me where it was coming from, but it had to be where the hole for the plug is? However, when I had it upside down, there was silver tape over the bottom where the drainage hole might have been but I did not want to incur damage by removing the tape. Thank you for clarifying for my next defrost.
  • Nancy Bates Oct 18, 2013
    Thank you for all of the suggestions. They are appreciated! Fortunately, there was no odor associated with this process. I do not wait until a non-frost free appliance to be heavily caked with ice before defrosting. What got my attention in the first place was the blue light indicator on the bottom right exterior surface where the control knob is showing the appliance is in "all is well" mode was out. That encouraged me to defrost it. I think there is an exterior drain opening issue but it can wait for now. I let it sit 24 hrs after defrost, removing the remaining standing water, cleaning, etc., to turn it back on, and another 24 hrs before putting back items needing to kept in there. Although it is working fine, the blue light remains off. My plan for the next defrost is to run the test tube brush or pipe cleaner through the drain hole to see if I can push it to the exterior freely. Thanks everyone.
    Master:
  • 492 Answers
Mae sure you leave the freezer upright for 24hours before you operate as the oil from the compressor drains out and you will ruin your freezer.
Posted on Oct 18, 2013
    Thank you; I did that. I appreciate all the suggestions and have applied most. I have not added food products yet, while I still have it in a test mode.
4 Suggested Answers
  • 161 Answers
SOURCE: kenmore freezer
Try cleaning out the drain opening with a pipe cleaner. Or use a turkey baster and force hot water into the drain. Rinse with a mild bleach solution to kill any mold. Another solution is to unplug the unit and let it sit for a couple of days to defrost completely. Sometimes during the humid summer the system just gets over burdened and doesn't defrost completely. This gets progressivly worse until you get this problem.
Posted on Jun 30, 2008
woodchuck789
  • 4070 Answers
SOURCE: I have a small (I'm guessing about 5 cu ft)
I would use a hairdryer to defrost the door secton with the other part closed off or covered.
Posted on Aug 30, 2009
  • 143 Answers
SOURCE: Sears Freezer, Model 253 9284013-unable to locate
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Posted on Oct 11, 2009
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
What could be wrong with it?
it sounds like your compressor is popped
Jun 05, 2014 | Kenmore 5 cu. ft. / 142 liter Chest...
My kenmore model 19502 freezer is not freezing
Have the same freezer bought the warrenty glad I did services tech said that he knew the porblem before he came to fix it compressor locked up at 7.9 amps he said this is an issues with 99.9 percent of this model. Light was on flashing but food would not freeze. Sears will replace for me they are giving me a diffrent model number. I had no power surge or nothing of that manner. Faulty appliance. A recall has'nt been issued... but it should
Oct 13, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
252 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
