Question about Bsn Medical Inc Vehicle Parts & Accessories
Switch wiring schematics - Bsn Medical Inc Vehicle Parts & Accessories
Find a wiring schematic for a hofner bass knock off?
It should still be close to a real Hofner bass
a common wiring configuration is
two pickups volume for each pickup, pickup selector switch,
bass on/off switch, and treb on/off switch
there are quite a few schematics available online...
http://www.hofner-guitars.com/information-service/vintage-wiring-schematics.html?___store=guitar_store_en&___from_store=guitar_store_de
Mar 06, 2015 | Bass Music
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Im taking out a switch in a four switch circuit
If you are planning to put 4 switches back in after the renovation, you need to make a wiring schematic of exactly how they are wired now and label each wire according to your schematic. Then when you put them back, everything will work. If you are going to use less light switches then the schematic will help with a smaller number of switches. These are 3-way switches, for your information, not regular 2-way switches!
Jan 02, 2013 | Dryers
Hello: I have a Levitron White decora 15 amp combination switch: I need to get a copy of the schematics as someone threw the schematics away... Geesh! Note The MFG part number is the same as the...
Hello.
There is no schematic shown online for that specific product.
Leviton shows a spec sheet on their website but no wiring schematic.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?sitex=10026:22372:US&item=8938
However the spec sheet does show the screw terminals on one side of device that indicate this is ordinary combo switch-outlet.
Open following link for illustration of combo switch-outlet:
http://waterheatertimer.org/images/Combination-switch-outlet-6.jpg
The problem that usually confronts people when they replace light switch with combo is that the combo requires additional neutral wire to power the outlet.
Neutral wires are the white wires twisted together and covered with wire nut that are pushed to back of electric box. Connect a short piece of white wire to the neutrals, and connect that wire to screw on combo device. If your electrical box does not have these neutral wires, you can get the outlet to work by using bare ground wire instead of white neutral, but I would never recommend this action as it violates national electric code and would not pass home inspection and would cause risk to electrician working on that same circuit who was unaware of a code violation.
Jul 23, 2011 | Leviton White Decora Rocker Switch &...
I ordered a replacement switch for the JED8430ADW. The previous switch was 7403P406-60. The replacement switch is 12002125. I have no clue how to re-connect the wiring. it looks nothing like the old...
There was a design change related to this switch. I had the same problem earlier today and figured it out by getting the schematics from searspartsdirect.com. There are two different schematics there (in English). The old schematic is labeled "DIAGRAM NO. 8104P688-60". The new one has five notes in the lower left (that don't help). The key is to split out the red wire coming back from the double burner element. The old way had it connected to "N" along with the RED source power. The new way has it connected to terminal "2" all by itself with the RED source power now connected to terminal "P2". But in addition, you have to add an extra jumper wire that should have come with your new switch that goes from "P1" to "S1". The other connections simply move from the old switch to the new where the locations can be seen on the schematics by referencing the wire colors (example: TAN wire moves from the old "3" to the new "4", etc.). If you are not 100% sure of what you are doing - you shouldn't try this. A wrong wire in the wrong place can short out 240V when you throw the breaker (boom!). Good luck. -- Mark.
Sep 10, 2010 | Jenn-Air JED8430 Electric Cooktop
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Bsn Medical Inc Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Bsn Medical Inc Vehicle Part and Accessory Expert? Answer questions, earn points and help others
