Question about Makita Drills
I Have a Makita 8406C core drill which Hums but wont turn., I have replaced the brushes and cleaned the armature but to no avail. I am looking for a wiring diagram for The makita 8406C or suggestions for repair. i see it hase some kind of controller which may be the fault but am unable to test further. All help appreciated. Ric
  • 31 Answers
Can you turn the armeture? If not you may have a frosen bearing
Posted on Jan 17, 2014
rowdy45176
  • 2176 Answers
SOURCE: wiring diagram for makita 6510 LVR drill
I can't find the wiring schematic online but if you can bear with me I will make some phone calls thurs. and get one faxed to me. It has been so long since I had one apart that I can't remember.
Posted on Feb 11, 2009
  • 14 Answers
SOURCE: makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Posted on Mar 04, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
SOURCE: Makita BHP451 Question
go with the hitachi, i've had 4 makita drills all with gearbox slipping. expensive to fix.
Posted on Feb 16, 2009
comax
  • 154 Answers
SOURCE: how to properly clean armature on cb748 core
If you are getting arcing on the brushes then most likely the armauture has failed and cleaning will not cure the problem. If the unit has been run with the brushes sparking for a while the field coil may also be faulty. Best thing at this point is to dismantle the unit and take the armature and field in for testing or take it to a Dewalt service center for repair.
Posted on Aug 05, 2009
Makita bhp454 overheated, not turning clockwise.
It is very common for the armature to overheat and melt down.
Open it up and inspect the armature, it will be very obvious it is burnt.
If it is the case, replace the brushes (#16) and the armature(#14)
Makita BHP454 18V LXT Lithium Ion Cordless 1 2 Hammer Driver Drill Parts
Dec 03, 2016 | Makita Drills
Makita hr3851 won't hammer or drill
Try pulling out the brushes and blow some air in were the brushes go it may have gotten some trash in between the brush and the armature . they may need to be replaced, here is a pleace that will give you a breakdown and sell you the parts. http://www.ereplacementparts.com/makita-hr3851-rotary-hammer-parts-c-97_380_491.html
Jul 30, 2016 | Makita Drills
Makita troubleshooting
The BDF452HW has a carbon brush motor - and they do eat up brushes quickly. The brush set number is CB440 - they are replaceable by removing the 2 screws on the rear cap, the connectors snap over the brush holder - take care not to bend the brush holders when changing, they are just thin brass.
If the tool is 'ticking' or 'grinding' when it spins check the condition of the armature before you install new brushes - the copper commutator should not look burnt or have raised segments - this is also a common repair on this tool. Replacing the armature is a fairly inexpensive and easy fix - you must split the entire clamshell housing to access this - be sure to fit all the components securely back into their slots or you may tear all the fan blades off the armature when you try and run it.
Jul 27, 2014 | Makita BDF452HW 18V Cordless Lxt Lithium...
My makita 6914D impact drill works fine when it will start. Sometimes when I pull the trigger nothing happens on either forward or reverse. When I change batteries it may or may not work . I checke
It could be your brushes are worn down and not fully contacting the armature. If they are very short and the armature comutator looks burnt, you need part number CB424 to replace your brushes. Most likely your problem is the switch. Sometimes the contacts in the switch get dirty or burnt and if you move the switch just right, a clean contact may be made but usually it won't work. The switch is part number 651939-6. Both are available on sites like www.ereplacementparts.com.
Mar 01, 2014 | Makita 6914D 12V 1/4 in. Impact
Drill is not working
first measure of the batterie if its loaden ,only if the brushes are to short replace also anyway the armature and brushes BOTH . it is not good to switch only the carbonbrushes because of a marketing technical design concept because of the heat dissipation that playing tricks insite the armature and it is cheap made by Johnson
sometimes the half value compared to other brandnames.
Armatures are new designed in a short time
23465970-2oroqqetjko0hjqmfukebeah-4-0.jpgleft the armature of the old but same cdd 18 milwaukee no problems you can change only the brushes and its working again right the same modificated armature marketing technical a new design of this JOHNSON Armature (Johnson is also used in Panasonic powertools bv EY7441 ) it has much more force in the same armature but the heat dissipation plays tricks and if the brushes are to short replace anytime BOTH (the brushes and the armature look at the difference of the turns of the coil front right look the later design more and thiny wire on it more power force but a bad heat dissipation in about 2 or 3 years the brushes are on its end take by heavy work a more powerful tool its better longlasting then this machines Makita has oft a better armature but there are also posibillities in some tools.
Feb 11, 2014 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita hammer drill ,there is power going through switch and controller but motor wont run
This is simple to fix.It sounds like you need to replace the brushes.There are two types of brushes ones that are easy to change and one that have small holes in the front part of the brush housing that require a small piece of wire that runs through the holes and keeps the brushes in place for reassembly.The wires length will depend on the vent that is used to pull the wire out when the armature is back in place and the front piece is bolted back together.While the armature is out blow everything down with compressed air and use a hacksaw blade to clean the grooves between the metal plates on the armature and add a thin coating of grease to both ends of the armature If they need it you might want to clean out the holes that the armature ends seat in.Thank you for choosing FixYa.com and Good Luck!
May 18, 2011 | Garden
Makita 6935FD has lost all torque. The drill varies speeds when not under load, but won't drive a screw. The battery is charged. If I get the trigger in just the right place the drill will hammer once,...
Remove the brush caps and have a look at the brush length.
If they are extremely short, or barely touching the commutator bars on the armature, you will need to purchase a brush set part # (193466-2). The way you are describing it behaving without a load, and charged battery, I can only assume this will fix it. The other thing you can do is open the clamshell housing and with a pick, attempt to move the armature fan and see if it will make several full rotations. I want to know if a piece of the magnet ring broke loose and is rolling around between the armature and the magnet ring causing your varying RPM.
Nov 20, 2010 | Makita Drills
Motor fails to run when trigger depressed
sounds like your armature and field is burnt. once they have both got hot you need to replace the armature and field as well as the brushes and holders.
Jan 24, 2010 | Drills
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
Aug 30, 2009 | Makita Hammering
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Drills Logo
194 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
