Question about Frigidaire Refrigerators
Frigidaire compact frig # FRT04L5DB0 runs but stopped blowing cold air. unplugged for a day and when I plugged it back in it seemed like it was blowing cold air but then it stopped but I could still hear it running. Any ideas?
  • Brook Lain Oct 16, 2013
    It's not the temperature controls as I've played with them. I think the freon needs to be replace but I can't find anything that tells me how to do it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Definitely needs a gas charge
Posted on Oct 17, 2013
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
My frig is making a loud knocking noise it seems to happen all day on and off and coming from the back of frig plz help
the fan that blows cold air from the freezer to cold storeage area , is going to brake .
Feb 18, 2012 | Kenmore Refrigerators
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
This frigidaire (side by side) only blows warm air on both sides
Good day,
First, I would unplug the machine, and then unplug the ice maker. Wait 20 minutes and plug in refrigerator. See if it cools without the ice maker in the equation.
Sounds more like starting components on the compressor, or a compressor starting to fail.
Post back with results.
Thank you.
Feb 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
Not blowing cold air
unplugged the unit, kept the doors closed about 10 to 12 hours plugged back in and in about 2 hours started blowing cold air into freezer another 4 hours was blowing cold air into refrigerator and continuily got back to the themostat settings,about 1 day. no food was lost because the doors were closed still keeping it cold. i think the fan in the freezer was frozen with ice,but could access it, not the main fan in the back the unit by the compressor,that was running fine. so basically i defrosted the freezer fan by unplugging it. this is the 2nd time in 4 years ive done this, well it beats spending 1000-1500 dollars to replace it TRY IT I HOPE IT WORKS FOR YOU BEFORE YOU CALL FOR SERVICE,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Blows warm air, unpluged it for 2 days plugged back in blew very
Either the start relay and start capacitor or the Adaptive Defrost control is burned out. If you have a voltage meter we can test a few things like the compressor and the capasitor. The part number for the Adaptive defrost is 241508001 and found inside the fresh food compartment behind the control panel. I can help you locate the problem if you like. Let me know, Thanks, Sea Breeze
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer not freezing frig not cold
the compressor with a picture of an Indian, its a techumseh. Is the compressor running? If not, could be stuck in defrost mode. Since you have looked at the compressor, there is two lines that go to it. If there is an oil cooler, then 4. Follow the line, smaller of the two that goes to the condensor, rad. With the fridge running, use your hand to feel how hot it is, if you find it hot enough that you can't leave you hand on that line, then its an inneficient compressor.
Feb 09, 2009 | Frigidaire FRS3R4E Side by Side...
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Frig just not Cold
you might have had freon leak out from it sitting unplugged how long were you gone ? plus you need to wait atleast 30 minutes when you unplug your refigerator then plug it back in you cannot keep plugging it on and off it will burn up the compressor / relay overload
Aug 28, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
107 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
