Question about Wildgame Innovations Micro Red 8-W8e Trail Camera
I have the WGI Micro 8 Red scouting camera and the LED screen flashes LOCK when I power it on. Ive made sure the SD card isn't locked, and even tried 5 other memory cards with the same result. It was working great, I took it back out to the woods and that's when the problem started. I reset the camera, and done a hard reset via customer service, and still cant get past it. Any help with this would be greatly appreciated.
3 Suggested Answers
  • 102366 Answers
SOURCE: need manual for 8.0 megapixels modell # N8D, infrared flash digital game scouting camera,real tree APG.
You may download the manual from here.
Posted on Feb 21, 2013
Testimonial: "Thank you SO MUCH. Thats just what I wanted. I've been looking all over for it. Again, thank you."
t0ny_pars0ns
  • 5412 Answers
SOURCE: Do i have to use a memory card in wildgame innovations w4f wgi camera
Is this information not contained in the manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Posted on Dec 25, 2016
PIR MODE SET UP
I use mine set up for motion sensitvity..this means something must enter the units field of view to be photographed..I set it for maximum distance and to take a photo every couple of minutes..I use an sd card thats 2mb yours may use a 4 6 or 8..look into the window display and see how many photos it will take..mine will do 3000 on the 2mb card..make sure the card is unlocked before putting it in the camera..and you have new batteries in it..
Jan 15, 2014 | WGI INNOVATIONS Video Cameras
Sd card full
try formatting to FAT32 or NTFS
Nov 15, 2013 | Wildgame Innovations Micro Red 8 W8E...
I was trying to upload pictures from a Olympus VG-110 micro sd flash drive. and i couldn't see the files saved in it.. why is this happening? Then we put the back the disk in the digicam and after turning...
SD cards (and most microSD adapters) have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
And yes, formatting the card will delete all the pictures on it.
Sep 13, 2013 | Olympus Vg110 Vg-110 Red Digital Camera...
My 5130 micro sd card of 8 gb has been locked
Hello Ashutosh,
By lock, do you mean password locked? Or just locked? Check your micro sd card for a small switch and make sure it is not set to lock. If there is not switch, try formatting your sd card.
Note: All files will be deleted from your sd card once you format it.
I hope this helped you.
You can rate my answer if you appreciate my help.
-damneddle
Oct 04, 2011 | Nokia 5130 Cellular Phone
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card when i plug say format but as i format it giving error of "Data write protected" but my micro sd card have no lock or other lock and the company of my sd card is Red bridge.Plz solve this...
Hello there!
Well somehow data on your usb flash is write protected, maybe before you locked part of your usb pen drive and losted that encryptor software on your usb.
Solution is next, find any software for formatting usb flash memory sticks, force format it and there you go. Thats about it! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Wildgame Innovations Micro Red 8-W8e Trail Camera Logo
81 people viewed this question
Top Wildgame Innovations Cameras Experts
teddyboy
Steve Mason
Are you a Wildgame Innovations Camera Expert? Answer questions, earn points and help others
