Question about Garage Door Laser Parking Guide
1999 c230 - how do i program the garage door function?
  • 2,113 Answers
I found this... hope it's what you need http://www.benzworld.org/forums/w203-c-class/1423284-c230-garage-door-opener-controls.html
Posted on Oct 16, 2013
My Sears craftsman 3/4 h garage door opener not function and the message on screen said press the push bar to activate control idid nothing happen
It sounds like limits and force have not been programed. If they have, go through the programming instructions again, then once complete press the push bar.
Jan 01, 2015 | Sears Craftsman LiftMaster Chamberlain...
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
2000 Bravada: How do I program the garage door opener in my 1999...
Thee best source of information can be found at www.homelink.com
Then select the program homelink hyperlink.
The procedure from the manufacturor is more accurate and informative than that GM provides.
Good luck
Apr 28, 2010 | Cars & Trucks
Garage code
In my Audi, and in my mother's Avalon, you choose which of the buttons on the visor you want to use, hold it down, and while holding it, you aim your garage door opener at the visor and press the button. This allows the car's memory to scan the code that the opener sends, and programs it into the car's opener for the selected button.
Dec 05, 2009 | 1998 Mercedes-Benz C-Class
How do you program the garage door opener on a
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Nov 10, 2009 | 1999 Lexus ES 300
Programming garage door opener in the visor of the 1999 nissan quest
here is a link to the owners manual for a 1999 nissan quest. The instructions for programming a garage door are on page 2-27. Copy and paste the link in your address bar. I hope it helps.
http://www.nissan-techinfo.com/refgh0v/og/quest/1999-nissan-quest.pdf
Oct 08, 2009 | 1999 Nissan Quest
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Got 1999 C230 Kompressor key. Do I need to program?
this should work straight away, but i would first put the key in the ignition, and put the ignition on for 30 seconds to a minute, then start it up
Feb 17, 2009 | 2007 Mercedes-Benz C230 Sedan
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Laser Parking Guide Logo
50 people viewed this question
Top Cars & Co Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Cars & Co Vehicle Part and Accessory Expert? Answer questions, earn points and help others
