Question about Canon Pixma MG5220 InkJet Printer
Paper feed the belt seams to be workin but the paper is not going in
  • 24 Answers
Try cleaning the feed rollers. If that does not work, new printers are very affordable due to the profit margin on the ink. In most cases with printers its best to cut your losses and opt for a new product along with reaping the benefits of newer technologies.
Posted on Oct 16, 2013
Thread pulling fabric through feed dogs
Usually when that happens you have the wrong needle plate on for the fabric. Now if you don't have an extra needle plate.... try floating a piece of tissue paper or tear away stabilizer between the fabric and the feed dogs. When the seam is finished just tear away the paper or stabilizer.
Another thing sometimes the problem lies in not having a long enough stitch for the fabric.
Mar 10, 2013 | Sewing Machines
Z42 not feeding paper
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Regards,
Sanath
Feb 20, 2013 | Lexmark Color JetPrinter Z42 InkJet
Paper jam door - I cannot open this no my HP 8250.
Turn off the printer, then unplug it from the power source. Clear the
printer of any paper that may be obstructing the paper path. Remove the rearaccess door. Gently remove the jammed paper from the printer, then replace therear access door.
Remove the rear access door to clear paper jams.If you cannot remove all jammed paper from the rear area of the printer, tryremoving paper jammed in the middle of the printer by opening the paper jamdoor located inside the top cover.
Open the paper jam door to clear paper jams in the middle of the printer.Plug the printer back in and turn it on.
In case of any doubt go to the following link and act accordingly
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386753&lc=en&dlc=tr&cc=us&product=443024
Sep 25, 2011 | HP Photosmart 8250 InkJet Printer
I have a question on my Kenmore sewing machine style 385.17626 When I start sewing, after a couple of stitches it starts to bunch up and not feed through. It's a tangled mess of thread and fabric. I'm...
Try using a double strip of tissue paper 1 1/2 x5/8 inch placing it about 3/4 inch under edge of fabric and middle of seam allowance. Start stitching on the tissue paper and continue onto the fabric to the end of seam. After that remove the tissue. You can also hold both threads and slightly pull them when you first begin the seam to help them reach the back feed dogs.
Oct 22, 2009 | Sewing Machines
Epson CX5000 Paper will not load. Tries to but says paper jam even when there is no paper jammed. Blank pages will go through during reset but not otherwise.
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results? Once we have this information we will try to fix the unit through email support.
Apr 29, 2009 | Epson Stylus CX5000 InkJet Photo Printer
I have a lexmark Z22 color inkjet printer. the problem that i am having is when i turn the printer on, it doesn't load the paper right, and then the power and paper light start to blink simultaneously and...
You may try the following for the paper feed issue:
Firstly, ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, you may try these instructions (use a regular letter size paper to test after doing the steps given below):
hope dis solves the issue.. try it out..!!
Apr 22, 2009 | Lexmark JetPrinter Z22 Color InkJet
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
I cant' get new paper installed on desktop calculator
There is a small **** right where the paper roll gets installed - it looks like the seam between the top and the bottom of the calculator. The paper feeds from the roll directly into this - maer sure you have a very clean edge to start with - then turn on the print function and push a button until it starts to feed through. Be patient with it but it will work.
Dec 20, 2008 | Canon BP120 DH Calculator
Alternator problems
Did you use a Kragen or other such cheap rebuilt? the failure rate on thos is terriable.
Oct 17, 2008 | 1987 GMC S-15 Pickup
Canon Pixma MG5220 InkJet Printer Logo
old marine
old marine
